Old 04-25-2018, 06:18 PM   #1
Dbunch9
Drives: 2010 Camaro 2SS
Valve seals
Alright next question. Can someone point me in the direction of how to install valve seals? The ones I took off my old heads look different than the ones that came with my gpi cam kit and I don't know if there's a part of the old ones I need to reuse or if what gpi gave me is enough. What I took off of the old heads looks like a bell and I thought the new valve seal might go in the but it's not making sense to me. My Google/YouTube searches failed me
Dbunch9 is offline   Reply With Quote
Old 04-25-2018, 09:05 PM   #2
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
The stock part is the seat and seal in one piece. Your aftermarket piece should have a seat, then the seal is a separate piece.
Install the seat. Then tap on the seal with a 13mm socket. Spring, valve, retainer... compress the springs and drop in the 2 keepers.
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
