03-26-2017, 03:22 PM | #1 |
Drives: 2017 Camaro 2SS Coupe Join Date: May 2010
Please help! Jacking up car to change tires
Hi there,
Soon it will be time for me to remove my winter tires and put back on my summers....but I am not sure where to put the floorjack to lift my car :( I have done a search, and I have seen all the pics where to put jackstands, or scissor jack, but I have not seen where you would place a floor jack to just change tires. I looked under the car, and I found these 4 elevated pieces on all 4 corners of the car near each wheel. Is this where you put the floor jack? I have attached a pic Thank you! |
03-26-2017, 04:21 PM | #2 |
Drives: 2011 SS/RS L99 Join Date: Nov 2016
Here
2011 SS/RS L99 - Summit White
CAI, Dyno Steve Tune - More to come... |
03-26-2017, 04:51 PM | #3 |
Homeless Life Chose Me
Drives: LS3 (sold 4/21) Join Date: Nov 2014
Or the rear diff
Pity a man in familiar places, who yet feels like a stranger.
03-26-2017, 04:55 PM | #4 |
03-26-2017, 04:57 PM | #5 | |
What about from where he jacked his front from? It doesn't look like those arrows |
03-26-2017, 05:18 PM | #6 |
Drives: 2014 Camaro 2SS RS & Ground effects Join Date: Apr 2014
I made 2 sets of these jack support pads and use them when only jacking up one corner with a floor jack. If I want all 4 corners up I jack up where N719SG pointed out except the front I jack it up on the control arm joint (Circled them not sure what the official name of it is called )and use the jack support pads for jack stands.
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260 Last edited by Stewart; 03-26-2017 at 05:36 PM. |
03-26-2017, 05:23 PM | #7 |
Banned
Drives: Camaro Join Date: Mar 2013
If you jack up your car in the center of your front cradle, it will bend. Ask me how I know.
03-26-2017, 05:24 PM | #8 |
I use the jack support pads because of the side ground effects. If I didn't use them the jacks would damage the side ground effects'
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260 |
03-26-2017, 05:35 PM | #9 | |
03-26-2017, 05:40 PM | #10 | |
I did it dead center of the cradle, now mine is slightly dimpled in.
03-26-2017, 05:42 PM | #11 |
You are welcome Skyset, glad to help. To make the jack support pads I used 1" flat stock (1/8" thick) and welded 1/2 " steel U channel to it. Then got some 1/2" nylon flat trim from Lowes and slide it into the bottom. Was cheaper to make it then buying 4 pre made ones.
03-26-2017, 05:47 PM | #12 |
Drives: 2014 2SS RS, 6 sp man Join Date: Feb 2016
I jacked mine yesterday to install the skip shift and I put the floor jack under the center like in the picture but before I lifted it i thought it was a bit light. i moved over to the pink circled area instead. Love the skip shift eliminator.
03-26-2017, 06:47 PM | #13 |
Drives: 2013 ZL1 Join Date: Nov 2015
More arrows and circles
03-26-2017, 07:17 PM | #14 |
Banned
That one yellow arrow is pointing the wrong direction.
