Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Members Area > Ask the Camaro Team
Old 06-25-2018, 12:51 PM   #1
Riker
Drives: 2017 Camaro 2SS A8
Is Stealth exhaust mode damaging at the track?
In the owner's manual, there is a single reference to using the Stealth option on our Engine Sound Management setting.
"The Engine Sound Management setting (if equipped) should not be set to Stealth Mode during track events and competitive driving."
My question is if this is mentioned because it is damaging to the dual mode exhaust valve or simply letting you know to keep it off for performance/lower restriction reasons?
This is pretty important for tracks with decibel limits, particularly Laguna Seca's 92dB limit. It would be great to know we can leave it on Stealth safely so that we can focus on driving rather than staying under sound check station limits.
TPNS5F
7/11/16 - 1100 - Ordered 2017 2SS at dealer
8/7/16 - Order requested to be cancelled
TRBTXD
8/9/16 - 2000 - New order placed
8/10/16 - 3000
~8/16/16 - 3400
9/20/16 - 6000 Delivered to Customer (That's me)
Riker is offline   Reply With Quote
Old 06-25-2018, 01:13 PM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
long tubes and exhaust with npp on the track is awesome lol let those bald eagles fly
kropscamaro16 is offline   Reply With Quote
Old 06-25-2018, 07:34 PM   #3
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
Awesome? Not when you get booted off the track for noise violation. Don't count on getting a refund.
Norm
'08 GT coupe 5M (the occasional track toy)
'19 WRX 6M (the family sedan . . . seriously)
Norm Peterson is offline   Reply With Quote
Old 06-25-2018, 09:49 PM   #4
h422694
h422694's Avatar
Drives: '16 Z06 7 Spd, 2024 High Country HD
Try setting it in "Tour". Should be much less restrictive and louder than Stealth but not nearly as loud as Track or Sport and should also pass the 92dB limit
h422694 is offline   Reply With Quote
Old 06-26-2018, 11:21 AM   #5
Riker
All the modes simply alter when the valve is open or closed.
Tour leaves the valve closed at all time outside of start-up, high RPM and high throttle input. Which means it will be open just as much as Sport/Track mode on the track. If you go WOT, Tour/Sport/Track are all the same loudness. The valve simply opens to the "loud/less restrictive" exhaust path. Closed makes the exhaust go the "quiet/more restrictive" path.
Sport/Track modes leaves the valve open in almost all circumstances outside of steady state speed above 10-15 mph with low rpm/throttle (avoids drone). Track opens up with even less RPM and throttle than Sport. But as I mentioned, when you are going WOT at the track, Tour will not make a difference outside of some braking zones where you are off throttle. But that doesn't matter at all since it is about peak loudness which is when you are WOT.
Stealth keeps them closed no matter what. The question is if it is damaging, not just lower performance.
TPNS5F
TRBTXD
8/10/16 - 3000
~8/16/16 - 3400
Old 07-02-2018, 04:27 PM   #6
kropscamaro16
Norm
lol only track around here that does that is laguna seca and im nowhere close to it
Old 07-03-2018, 08:27 AM   #7
Norm Peterson
I guess you're fortunate for the most part. For now, anyway.
It would be good to get this question answered for those who face noise limits now. Lime Rock in CT is another track with unusually restrictive sound limits (on most days).
Norm
Old 07-03-2018, 09:59 AM   #8
HartfordRacingCaptain
HartfordRacingCaptain's Avatar
Drives: 2017 Camaro 1SS, 2023 Colorado Z71
No issues with stock SS's (including 1LE's) w/ NPP in track mode at Lime Rock
https://www.camaro6.com/forums/showthread.php?t=525538
See page 2 of link for confirmation.
2017 1SS, Summit White, Black 2SS Interior, MRC, NPP
2023 Colorado Z71, Nitro Yellow
HartfordRacingCaptain is offline   Reply With Quote
Old 12-24-2018, 04:51 PM   #9
royriccomini
royriccomini's Avatar
Drives: Zl1 1le
Norm
I have the same question...did you find the answer anywhere else?
royriccomini is offline   Reply With Quote
Old 05-25-2019, 12:06 PM   #10
Heartbreaker
Heartbreaker's Avatar
Drives: 2020 Camaro ZL-1 1LE
At NCM today and got a black flag in the first session for exceeding the sound limit. Can we use stealth mode? I’m running long tubes,cats and the stock muffler.
Heartbreaker is offline   Reply With Quote
Old 05-28-2019, 11:01 AM   #11
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
Is there a team Camaro rep anywhere on this thread. The members now know more about the 5th gen then anybody.
rontammy0 is offline   Reply With Quote
Old 06-29-2019, 07:10 AM   #12
FollowMyLine
Driver for Hire
FollowMyLine's Avatar
Drives: 22 Camaro 2SS 1LE M6
I’m curious what NCM did to help you pass and keep running. I know when I was there, they said “if you blow sound, we will help get you down to the 103dB limit, we want you out on the track.” Also, what did you end up running there?
Luan Zeqollari
2022 Camaro SS 1LE M6 - Wild Cherry Tintcoat - Delivered 9/20/21
2018 Camaro SS 1LE - Hyper Blue Metallic - RIP 6/6/20
YouTube Channel
FollowMyLine is offline   Reply With Quote
Old 07-03-2019, 10:56 PM   #13
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
The 2019 Corvette owner's manual provides a little more information (p. 162):
"Do not place the vehicle in
Engine Sound Management –
Stealth mode. Damage could
result to exhaust valve actuators
https://my.chevrolet.com/content/dam...ers-manual.pdf
I'd say the systems and actuators are similar enough that this probably applies to the Camaro as well and answers your question.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
vtirocz is offline   Reply With Quote
Old 07-03-2019, 11:30 PM   #14
DenverTaco07
DenverTaco07's Avatar
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot
if warning is for damage to actuators, leave it in track and block the outer pipes...bananas or something?
2017 SS 1LE | HBM | Vortech V3-Si supercharger (620RWHP and 575ft lbs) | PDR | Black Bowties | Illuminated Front Black Bowtie | Illuminated Door Sills | Smoked Tails | vented seats mod
DenverTaco07 is offline   Reply With Quote
