07-12-2010, 10:46 PM | #1 | |
2010camaroSS
Drives: 2010 Camaro SS Join Date: Feb 2010
LS9 Camaro vs maggie LS3 Camaro
I want to see some dyno charts of a LS9 camaro vs a maggie 2300 camaro. Or if someone has the charts overlaid together would also be great just want to compare
07-12-2010, 10:52 PM | #2 | |
2010camaroSS
also could they both be within the range of 600rwhp
07-13-2010, 05:53 AM | #3 |
Drives: Maggie blown LS3 vette Join Date: Aug 2009
I just don't think that there's a huge population of LS9 Camaros out there. I've heard of a couple that were put together. It takes big dollars to do the swap. You can forge an LS3 for a hell of a lot less and come out with more.
I think you'd have to be very lucky to find one at 600rwhp anyway. A lightly modded ZR1 vette could lend you a dyno chart. No shortage of 600rwhp Camaros on this site for comparison. |
07-13-2010, 12:27 PM | #4 | |
Moderator.ca
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
07-13-2010, 01:36 PM | #5 | |
2010camaroSS
well i just would want to see dyno's of both to at least get a comparison of the hp and tq curves
07-13-2010, 01:37 PM | #6 |
Moderator.ca
but once its modified, the curve changes.
07-13-2010, 02:09 PM | #7 | |
Okie doke
Crowley
07-13-2010, 02:11 PM | #8 | |
Moderator.ca
07-13-2010, 02:35 PM | #9 |
Petro-sexual
OEM boost on LS9 is 10.5 psi I believe.
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // RFBG // Soler 103 // TooHighPSI Port Injection // THPSI Billet Lid // FF // Katech Drop-In // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
07-13-2010, 06:18 PM | #10 |
Hennessey Performance started placing the LS9 engine in the 2010 Camaro in January 2009. Stock LS9 Engine produces 638bhp and the version we install produces 725bhp. In April 2010, our vehicle was tested by Road & Track Magazine. Full details are available below with the following links:
PDF Data of full Vehicle Results from Testing PDF Comparison of Hennessey HPE700 vs Chevrolet ZR1 vs Stock Camaro Video of HPE700 Camaro being tested by Road & Track Magazine Full Article as found in April 2010 Issue of Road & Track This information should assist you in your research. The LS9 Powered Camaro by Hennessey Performance is currently for sale as 2011 Models, Limited to 24 units. Call 979-885-1300 or email sales@hennesseyperformance.com for all inquires on purchasing one of these vehicles. Speak to you soon, James |
07-13-2010, 07:20 PM | #11 |
I want one of each
07-13-2010, 07:47 PM | #12 |
Drives: Various Join Date: Sep 2009
mag Vs ls9
All,
Hopefully attached is a comparisson between a Magnuson TVS 2300 and a LS9 TVS 2300. Sorry for the poor quality, but you should be able to see that on the same engine, exhaust and intake also at the same supercharger speed the graphs show next to no difference, which is not suprising since they share the same supercharger rotating assembly (Eaton TVS 2300). Essentially there is no significant performance difference between the two units under the same operating conditions, however the LS9 engine has a significantly better rotating assembly (Crank,Rods and Pistons) than the LS3 and worse cylinder head flow for the $22,000 it costs, but it can take significantly more spark due to its port design and reduced CR.. Best Regards Graham Last edited by Graham Behan; 07-14-2010 at 08:32 AM. |
Similar Threads | ||||
New Camaro Exterior and Interior Stainless Steel Trim Parts from RPI Designs! | RPI Designs | Cosmetics and Lighting Modification Discussions | 36 | 04-02-2020 05:32 PM |
5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 151 | 05-07-2015 05:52 PM |
GM unveils Jay Leno Camaro, Camaro Synergy, Camaro Chroma, Camaro Dusk at SEMA | irocnroll | 5th Gen Camaro SS LS LT General Discussions | 101 | 02-27-2012 12:25 PM |
Gran Turismo 5... No Camaro? | 5thGenOwner | 5th Gen Camaro SS LS LT General Discussions | 111 | 12-06-2011 10:06 AM |
LS3 engine specifications | Tran | Wiki | 3 | 10-06-2010 10:56 PM |
