02-16-2014, 09:54 AM | #1 |
Drives: camaro ss Join Date: Dec 2013
suspension 101
other than lowering springs and sway bars what else is out there thats worth buying for a suspension upgrade ..
2010 2ss/rs/GFX
Favorite L99 Kooks LTs no cats Corsa Exhaust Knn intake ( rotofab soon ) Seibon Hood Seibon Trunk pd Springs Giovanna Staggered 22" |
02-16-2014, 10:33 AM | #2 |
Drives: pleather and Chiclets Join Date: Mar 2012
Depends on what your goals are and if you track car.
02-16-2014, 02:13 PM | #3 |
street car mostly
2010 2ss/rs/GFX
02-17-2014, 08:21 AM | #4 |
Drives: '69 SS Convertible Join Date: May 2009
Cradle bushings. You can get by with just some inserts if you only have basic bolt on stuff.
From there, coilovers, rear end bushings, upper control arm bushings, trailing arm, toe rods.
Build Journal |
02-17-2014, 08:47 AM | #5 |
Drives: Race Car Join Date: Sep 2009
My advice is to start off with a good set of adjustable sway bars that will give you the ability to change settings in the future. After that, Trailing Arms and outer T/A bushings, toe rods, and then subframe bushings. As "caverman" said, if you are only planning on staying with basic bolt-ons and street driving, inserts would work fine. But if you ever plan on taking it to the track or getting into harder launches, the full bushings make a big difference. Call Kyle at the shop, and he can help you decide on the best parts for your situation.
02-17-2014, 09:06 AM | #6 |
Alignment sways springs, wheels and tires. Cant recommend what these others are saying for a street car.
02-18-2014, 11:07 AM | #7 |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
Bushings:
Solid rear cradle - Pfadt or ADM Performance. Makes the rear end become solid withthe rest of the car. Really plants the rear wheels. Radius Arm inserts - Improves steering response. Whiteline or Prothane have the best Steering rack - Improves steering response. Whiteline or Prothane Toe rods & trailing arms - I prefer the Pfadt. With the rear sways: go with the ZL1 spec, but with your 2010 you'll need to upgrade the lower control arms so they will fit. Also upgrade the sway bar endlinks. Once again, Pfadt. This all sounds like a track setup, because it is. However, this is exactly what I am working on putting underneath my daily driver.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
02-18-2014, 12:32 PM | #8 |
After Sways and springs/coilovers, the Subframe bushings, upper control arm bushings, Toe rods and trailing arms are the next biggest bang for the buck. The Prothane radius inserts are a good cheap mod as well.
Let me know if I can answer any questions. Best regards, Tyler 888-308-6007 |
