12-13-2014, 01:31 PM | #1 |
Drives: Fastest 2010 Camaro V6 Join Date: Apr 2010
LLT/LFX Engine Oil Cooler
So I've been thinking about how to get an oil cooler on my car since I have high oil temps when racing and traditional oil coolers use a sandwich plate to run the lines. While searching for something to help I came across the Traverse Oil Filter Housing, it looks like it will hook up to the side of the engine. From that point instead of a filter, run a remote oil filter adapter that will use a standard oil filter, then run the lines to an oil cooler and then back to the engine.
Cheapest I have found the filter housing is $52, a lot cheaper than what the Camaro's filter housing costs. Only problem I might see is room, but since it hugs the engine and the adapter plate will be pretty thin, it could work. |
12-15-2014, 04:55 PM | #2 |
Interesting idea. Would you run this in addition to the factory filter or run all new remote filter and cooler?
CAI intake | OBX LT Headers | Flowmaster AT Exhaust | Trifecta Tune | SS Rear Diff, Axles & Driveshaft Zex 100 Shot Nitrous | Konig Airstrike Wheels | Custom Engine Cover, Fuse Box & Underhood Bowtie Eibach Springs & SS Sway Bars | BMR Strut Brace | Drake Shifter | Vitesse Paddles | 13.26 @ 105.88 mph |
12-15-2014, 07:34 PM | #3 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
I wonder if the LF3 oil filter adapter would work. It looks like it's already plumed with lines for an oil cooler...
12-15-2014, 08:01 PM | #4 |
Jan
Drives: 2010 Camaro 1LT Red Jewel tintcoat Join Date: May 2010
12-16-2014, 11:29 AM | #5 |
New filter, would go with a regular type filter instead off this element type.
12-16-2014, 04:49 PM | #6 |
Looks like there would be issues with space on the Camaro. Crossmember and/or frame rails could cause issues. It would be hard to know for sure until someone tried though.
12-17-2014, 12:15 PM | #7 |
Oil cool er was available on the 2012 Impala with the LFX.
http://www.tonkinonlineparts.com/pro...e=0&searchTerm=
Retired United States Army
Bernadette: 2LT/RS, ABM #2041 of 3903 ZL-1 Springs | CAI | Muffler delete | Magnaflow resonator | LED DRL | DRL harness | RX Catch Can | Mini me Cortana: 2015 Harley Davidson Road Glide Special V&H Power Duals Headers & Oversized 450 Raider mufflers | Screamin' Eagle Stage 1 Chisel Extreme intake | Screamin' Eagle Stage 1 programmer | Klock Werks 12" Pro-Touring windscreen Own an Aqua Blue Metallic Camaro? Click here to join us on Facebook and help us in establishing the Aqua Blue Registry to locate all 3903 of these beautiful Camaros! |
12-17-2014, 12:18 PM | #8 |
$200 and it sandwiches between the filter and the filter housing. I'm sure with somemore research an adapter that fits the LLT can be found cheaper.
12-18-2014, 01:13 PM | #9 |
Don't know if it would fit, shock tower in the way.
Need a real oil temp sensor to see if is needed, I don't like the calculated on we have. Don't get the oil over 210 and it can't boil off water that condensates. |
12-31-2014, 03:26 PM | #10 |
HAHAHA, ok so there was a very old thread about that. Where I was trying to make an oil cooler, I bought that part, and we had all sorts of problems. Ill try to take some pictures of my setup later and post them for ya. They ended up doing a lot of work to that pice to make it fit properly, if you have long tube headers, it becomes even more of a problem. It not as easy as I thought it should have been. They had to mill the in and out oil lines in to the part pictured above, full filter relocation, and like idk 6 feet of line. I love the fully custom setup.
02-10-2016, 09:08 AM | #11 | |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
02-10-2016, 05:33 PM | #12 |
Never did, did some research and it is mainly for road racing. Since my little sprints down through track are less than 12 seconds it isn't heating it up too high.
02-11-2016, 12:44 PM | #13 |
Drives: 2010 camaro limited edition turbo Join Date: Mar 2014
MagnumForce. What is the part number for the oil filter adapter shown at the top of this page and/or the complete model, year, etc. of the application? This looks very interesting! I had to machine my adapter because I didn't think any other casting was available other then the one on the LLT, which is a nightmare, bulky casting with no way to plumb auxiliary oil filter, cooler. This is the one I machined. Thanks for sharing!
