#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Transmissions
Old 04-15-2020, 01:22 PM   #1
EddieM92
Instagram- _2sslow_
EddieM92's Avatar
Drives: 2016 Camaro 2SS
A8 transmission fluid change
I was looking into changing my automatic transmission fluid again because it has started to shudder again and I recently did the fluid change at the dealer under warranty in June 2019. I was wondering if anyone has used Royal Purple Max ATF Dextron
Instagram- _2sslow_
2011 Camaro LT RS (Sold)
2011 Range Rover Sport HSE (Sold)
2016 Camaro 2SS NPP, TSP headers & Xpipe, Skid e85, CAI Intake, MSD IM, 95m TB, BigPowerRacing Tune, H&R Lowering springs, BMR sway bars
EddieM92 is offline   Reply With Quote
Old 04-15-2020, 01:41 PM   #2
HCI2000SS
HCI2000SS's Avatar
Drives: 2018 Camaro V6/RS
So you had the latest fluid and flush procedure done, and it's now shuddering again?
HCI2000SS is offline   Reply With Quote
Old 04-15-2020, 02:14 PM   #3
EddieM92
Instagram- _2sslow_
EddieM92's Avatar
Yes it is so I wanna try something other than Mobil 1 now
Instagram- _2sslow_
Old 04-15-2020, 05:25 PM   #4
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
If the latest Mobil1 LV fluid (19417577) didn't help, chances are you need a new torque converter and not yet another different fluid.
735 rwhp | 665 rwtq
Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods
JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune
1100 - 1/30/18 | 2000 - 1/31/18
3000 - 2/06/18 TPW 2/26/18
3400 - 2/19/18 | 3800 - 2/26/18
4300 - 2/27/18 | 4B00 - 3/01/18
4200 - 3/05/18 | 4800 - 3/14/18
5000 - 3/16/18 | 6000 - 3/19/18
arpad_m is offline   Reply With Quote
Old 04-15-2020, 06:24 PM   #5
EddieM92
Instagram- _2sslow_
EddieM92's Avatar
I wanna try one more fluid swap but different brand and if it doesn’t work then last resort is gunna be torque converter
Instagram- _2sslow_
Old 04-15-2020, 10:46 PM   #6
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
You still under warranty? If so I’d totally make them get the new tc.
Though I heard that they no longer replace them
Bumbleboy92 is offline   Reply With Quote
Old 04-16-2020, 12:07 AM   #7
EddieM92
Instagram- _2sslow_
EddieM92's Avatar
No warranty’s been up for the last 6 months unfortunately but even when I was dealing with the issue then they made it clear they weren’t gunna replace that.
Instagram- _2sslow_
Old 04-16-2020, 07:46 AM   #8
arpad_m
arpad_m's Avatar
They will if you pay for it. I see no other way, you're out of warranty, and if the clutches are damaged, another fluid won't help.
The revised OEM TC costs about $3-400, which isn't horrendous (although at this point you may even want to go aftermarket, say, Circle D), the real issue is labor, not sure you want to support this seemingly unhelpful dealership.
735 rwhp | 665 rwtq
Old 04-17-2020, 08:49 PM   #9
EddieM92
Instagram- _2sslow_
EddieM92's Avatar
Bump
Instagram- _2sslow_
