11-04-2015, 06:58 PM | #1 |
Drives: 2015 1SS, 1LE, Recaro, NPP Join Date: Apr 2014
Suspension upgrades to help get a better 60'
One of the things I want to do this is to upgrade the rear suspension so I can launch harder. I talked to JDP Motorsports and they recommend their "Anti wheel hop" package. The price is exactly what I'm looking to spend, ~$500. Is this the best bang for my buck out there? What have you guys done to help cut a better 60'?
Thanks. http://www.jdpmotorsports.com/manufa...s-zl1-jdps1008
2015 Summit White 1SS, 1LE, Recaros, NPP
498 RWHP 447 RWTQ (Motor) 647 RWHP 723 RWTQ (150 Shot) 12.1 @ 117 (Motor) 11.7 @ 129 (Nitrous) Nitrous Outlet Single Nozzle Kit | Stand Alone Fuel Cell w/ C16 | Custom Grind Cam | Stainless Power 1 7/8 LT Headers | CAI Intake | ATI Super Damper | BMR Trailing Arms & Toe Links | Prothane Polyurethane Sub-frame Bushings | JDP Upper Control Arm Bushings | MT Drag Radials | Tuned by SS Motorsports Youtube Channel: Click Here |
11-04-2015, 07:16 PM | #2 |
Stovebolt BluFlame 6
Drives: '12 2LT/RS, IBM; '20 Traverse Prem Join Date: Oct 2011
JDP has a reputation on this site as being one of the best places to go to for advice and parts. Both (advice and parts) are high quality and bring great results.
11-04-2015, 07:44 PM | #3 |
Drives: Camaro Justice Join Date: Jun 2007
I am not a fan of any poly sub-frame bushings currently available. These are barely better than the 2010 - 12 OE bushings.
Your 1LE has improved solid rubber rear bushings and much improved front bushings. I wouldn't replace them with the poly that is available. Solid mounts will be a big plus, but they do shift strain and load to the sub-frame. I am partial to the DSE aluminum sub-frame bushings. The Z/28 trailing arm knuckle bushing would be a plus, but they are not sold as a part separate from the Z/28 hub. The first place I suggest you look for improvement is to get your alignment checked. For drag racing and hard launches the critical specs are: Rear Camber 0.00 Rear Toe IN 0.12 Total Toe IN 0.24 What tire pressures are you launching with? |
11-09-2015, 07:27 PM | #4 |
'It's an experiment'
Solids for sure, I did the BMRs and it was not enough. Also did more upgrades, but those and trailing arm/bushings would be a good start. Justice Pete and JDP are top notch...
-Don
747 RWHP 794 RWTQ
11-10-2015, 01:15 PM | #5 | ||||
Drives: 2011 Camaro SS/ 2016 Camaro SS Join Date: Jun 2009
Kind regards, Jordan Priestley 888.308.6007 |
