07-01-2009, 11:42 AM | #1 | |
SS Lightning
Drives: An SRT8 Join Date: Feb 2008
I got a hommework question, need help
Could someone tell me 5 reasons a car would shimmy and vibrate, my instructor give us questions like these every night
and I'm stumped Where the hell is spike when you need em, lol
07-01-2009, 11:47 AM | #2 |
Ragin' Cajun
Drives: '02 Camaro SS - '10 CGM 2SS/RS Join Date: Jul 2008
You mean while driving? Unbalanced wheels, bent rims, etc, cause vibrations in the steering wheel.
07-01-2009, 11:53 AM | #3 | |
SS Lightning
well, that's 2
07-01-2009, 11:55 AM | #4 |
Do all they have to be driving? If not then a misfiring cylinder can cause a vibration at idle. Or a big cam can always cause a little shaking
Warped brake rotors will cause shaking when braking. Rough Road |
07-01-2009, 11:58 AM | #5 |
General Motors Aficionado
Drives: 2023 GMC Canyon, 2020 Colorado Join Date: Aug 2008
A car with screwy cylinder deactivation will shudder a bit.
Same with cars with engine start/stop hybrid tech.
2023 GMC Canyon Elevation 2020 Chevrolet Colorado W/T Extended Cab (State-issued) |
07-01-2009, 11:59 AM | #6 |
Ragin' Cajun
Vibration when slowing down is the rotors and if the lugnuts aren't tight and good, it'll shake as well.
Those are the only experiences I've had with a shaky wheel.
07-01-2009, 12:05 PM | #7 |
SoCal C5 Family Member
Hmm I would say clogged fuel filter and bad fuel pump
My baby Jane!
I still love the Camaro |
07-01-2009, 12:09 PM | #8 | |
SS Lightning
yeah while driving, and thanks for a the good answer
07-01-2009, 12:19 PM | #9 | |
SST...
Drives: SST Camaro 2010 Join Date: Oct 2008
Front End - Out of balance tire Cupped tire Tire that is overworn/belts showing Tire with a "bubble" Bent rim Loose lug nut(s) Warped Rotors Bad Wheel Bearings or bearings with little grease Front End misalignment, bad caster/camber/toe-in Sticking brake Bad brake hose Malfunctioning ABS Bad Ball Joint (cars without struts) Broken/Bad/Leaking Shock Rearend - Many of the above, plus Bent axle Sticking Locker and/or Posi differential Hanging emergency brake Damaged Ring & Pinion Damaged Spider Gears Mid Area - Worn U-Joints Bent Driveshaft Worn Transmission Bearings General Transmission Problems Flywheel/Clutch/Pressure plate and/or flexplate weight missing And then about a million things that the engine could contribute... Hope this gives you a couple of ideas. |
07-01-2009, 12:41 PM | #10 |
Future Z28 Owner.
How about a very bumpy road.
07-01-2009, 01:31 PM | #11 |
Broken motor mounts?
07-01-2009, 02:16 PM | #12 |
Drives: vrooooom vrooooom Join Date: Dec 2008
bad alignment
"With a light touch on the brakes, run the revs up a bit. Slip off the brake and bury the throttle. There's a light chirp as tires scratch for bite. Then comes a sub-5.0-second sled ride to 60 mph. A tick over 13.0 sec. and you're through the quarter-mile. It's a rush, of course, but not overly dramatic. Try the same thing with this pair's predecessors of 1970 or so and you'll find yourself in a bit of a wrestling match. Ain't progress wonderful? Maybe yes, and maybe sometimes it's fun to wrestle."
07-01-2009, 02:30 PM | #13 |
Booooosted.
All very good answers. That's more than 5.
07-01-2009, 02:31 PM | #14 |
Booooosted.
Earthquake.
Similar Threads | ||||
LS3 Transmission Question | Seawolf | 5th Gen Camaro SS LS LT General Discussions | 13 | 06-12-2009 02:16 PM |
Ridiculously Stupid Question | Ferrarimk13 | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 19 | 05-28-2009 08:53 PM |
Question about Order # VS. Workbench Number | TJTKSDMJ8 | Camaro Price | Ordering | Tracking | Dealers Discussions | 27 | 05-06-2009 12:05 PM |
Question about the After.... | Tecca | Camaro Price | Ordering | Tracking | Dealers Discussions | 1 | 04-15-2009 04:05 PM |
OK WILL SOMEONE PLEASE ANSWER THIS QUESTION OM FINANCING | leatherneck | Camaro Price | Ordering | Tracking | Dealers Discussions | 22 | 03-26-2009 03:53 PM |
