Old 04-04-2022, 06:33 PM   #1
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
Doors lock by themselves
Had this car for a few years and never had this problem. Two weeks ago I was getting ready to leave and my car doors were locked. I never lock the doors and the key stays in the car(not in the ignition) since it’s in my garage. Went to leave today and had the same problem. Anyone have an idea of what could be causing this all of a sudden. I haven’t made any changes to anything in months.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
Old 04-04-2022, 07:49 PM   #2
gtstorey
Mine does this occasionally and seems to be worse after washing it. There have been discussions that it’s a chafed wire or corroded connector in the door or hinge area but I haven’t seen any post that confirmed this. I just live with mine.
Old 04-05-2022, 07:37 AM   #3
BLU DUCE
BLU DUCE's Avatar
Replace batteries in the ]FOBS] That is what fixed mine.
Old 04-05-2022, 04:29 PM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Hmmm, my FOB batteries are 12 years old and still work great. Have never had to replace them..
Old 04-05-2022, 05:04 PM   #5
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
There are some settings in the config menu you could look at, just to make sure.
Rock-It Man is offline   Reply With Quote
Old 04-05-2022, 05:37 PM   #6
Camaro2ss2010
I will try this, won’t hurt anything.
Old 04-05-2022, 05:39 PM   #7
Camaro2ss2010
I took the factory radio out a few years ago and do not have this option anymore unfortunately. Good thought though.
Old 04-05-2022, 06:25 PM   #8
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
If your vehicle battery is dead/dying this can happen, too. Haven't verified on my car specifically, but I do know that some cars when the battery is disconnected/reconnected it will/can lock the doors.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 04-05-2022, 07:06 PM   #9
Camaro2ss2010
Battery is less than a year old.
Old 04-05-2022, 07:52 PM   #10
gtstorey
Mine did it when the battery was fairly new also.
Old 04-05-2022, 08:58 PM   #11
witenite
witenite's Avatar
Drives: 2010 2SS non RS
Mine started doing this randomly also. I would say it started late last summer and probably can count on one hand how many times this has happened. So not often.
Car battery was replaced in November of 2019 and replaced both fob batteries maybe 3-5 yrs ago.
Only noticed it when washing/cleaning when opening and closing the doors they sometime lock themselves.
I will add my car has been sitting for long periods since COVID hit and I have worked from home most of the time. As gtstorey said so far I just live with it.
witenite is offline   Reply With Quote
Old 04-06-2022, 07:35 AM   #12
gtstorey
I've looked through the settings for any type of auto lock feature and didn't find anything that looks even close to right. Really mine is to random to be anything it's "supposed" to be doing.
Old 04-07-2022, 09:20 AM   #13
NOT A 45
NOT A 45's Avatar
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3
Your remote control door lock receiver operates on the class 2 communication network and the radio does as well. If I was working on your car the first thing I would do is disconnect the radio and see if the problem goes away. I know what your going to say, the radio has been in there for a long time without any problems.....but I've encountered this many times. They work fine until they don't.
NOT A 45 is offline   Reply With Quote
Old 04-07-2022, 04:08 PM   #14
Camaro2ss2010
Doesn’t everything work fine until it don’t? I did have a problem with that a while back but it was for locking/unlocking at a distance.
