02-04-2018, 06:54 PM | #1 |
Drives: Camaro 2014 V6 2lt Join Date: Apr 2016
Damaged rear lower fascia
1
02-04-2018, 09:53 PM | #2 |
SoCal C5 Family Member
Drives: 1996 Z28 SS & 2014 ZL1 Join Date: Apr 2009
It depends on whether or not you have the performance exhaust option (2 outlet tips on each side)
The top number (22829476) is for the standard exhaust cover. The bottom number (22829477) is for the optional performance exhaust cover. Replacement of the part is not too tricky. It is best to have a helper to disconnect the 2 cable harnesses. Videos can be found on YouTube. The worst part is transferring the 2 lower cover brackets over to the new piece. You will have to drill out 2 rivets that are used to retain the brackets to the bumper cover. (Part 22 in the attached image)
Vance Chula -
1996 Camaro Z28 SS #1688 2014 Camaro ZL1 Coupe #1956 |
02-05-2018, 12:18 AM | #3 |
Drives: 2014 yellow 2SS/RS Join Date: Apr 2015
Don't think there are any rivets to drill out but I can't quite remember as I added the zl addons mudflaps a while ago. But if there is you just have to pull the rear wheels off and drill them out. Also it is very easy 1 person can do it. No wiring harness connected to that piece. Just about 10 screws or so. I changed mine to the zl1 diffuser with the dual tips. Best of luck
K&N, Borla ATAK axle back, resonator delete, Speed Engineering headers,Vitesse, Zl1 wheels, ACS rocker panels, 1LE splitter
