Old 12-27-2019, 08:07 PM   #1
Hogiewan1
Drives: 2012 Camaro SS covertible
Help with replacement bushing: Rear lower outer control arm Knuckle bushing
I hope someone can help. While installing BMR rear trailing arms, toe rods, cradle bushings.... We notice my rear lower outer control arm bushing that is located in the knuckle is in rough shape and needs replacing. Does GM or anyone make a replacement? We removed it easier that any of the other bushings, LOL, but no one seems to have a replacement or part#. All I seem to come up with is buying a whole knuckle just to get the bushings. Silly! Any suggestions would be appreciated.
Thanks to the person I copied this picture from!!!
Hogiewan1 is offline   Reply With Quote
Old 12-27-2019, 09:32 PM   #2
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
Check this out. Hope it helps.
https://www.suspension.com/superpro/spf2866k
More to come.
Black_SS10 is offline   Reply With Quote
Old 12-28-2019, 04:19 PM   #3
Hogiewan1
Thank you very, very much. I just ordered them!
Old 12-28-2019, 05:16 PM   #4
Black_SS10
SomeguyK
Black_SS10's Avatar
Awesome. Your welcome.
More to come.
Old 08-24-2023, 07:38 AM   #5
Sheldonay
No, it's not an SS
Drives: 2014 Camaro V6
Hogiewan1
Did you replace the bushings and if so how difficult was it? Did you need to press them in?
I ask because my car (2014 Camaro) failed inspection at the mechanic due to having a little bit of play in the rear knuckle bushings (I'm assuming the control or trailing arm bushing)
Thanks
Shel
Sheldonay is offline   Reply With Quote
Old 05-25-2024, 01:40 PM   #6
jackrwall
Jack Wallace
jackrwall's Avatar
Drives: 2012 Camaro 2SS/RS
Originally Posted by Sheldonay View Post
Hogiewan1
Thanks
Shel
The bushings are a bit of a pain to swap, but it can be done with the small 2-ton puller from O'Reily's and a lot of patience.
jackrwall is offline   Reply With Quote
