Old 02-05-2020, 06:29 PM   #1
BigJ
BigJ's Avatar
Drives: Red 2013 Camaro SS, Black 1980 Z28
To Spacer or Not to Spacer!???
Been thinking about using a spacer on my rear wheels. I've heard and read a lot of opinions about why or why it's not safe to use spacers. I know that if I do decide to use them, I want hubcentric spacers. What do you guys think about spacers? And which ones do you recommend? Eibach makes some and I know Eibach is pretty reputable. Thanks for the feedback.
I love GOD! I love my family! I love fast cars!
BigJ is offline   Reply With Quote
Old 02-05-2020, 06:38 PM   #2
IKILLEDSUPERMAN_ZL1
Drives: 2011 Camaro SS
I've been running 20 mm hub centric spacers on my car for over a year. No issues at all. I use loctite and torqued them to 130 ft lbs. I've had the wheels off to do the brakes 6 months ago. I check them with the torque wrench and everything was still good. I have put about 10000 miles on them. I got mine off Amazon too. Nice aluminum peices.
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
IKILLEDSUPERMAN_ZL1 is offline   Reply With Quote
Old 02-05-2020, 09:57 PM   #3
xstuntman
Drives: 2012 Victory Red LFX
I've been running 1.5" hubcentrics on the rear of my square body 4wd Suburban to widen the rear track width to match the front for a while now with no problems.
I can't imagine a Camaro would or could generate more shearing force than the a 6000 pound 4wd Sub does.
2018 SS wheels, red Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, front grille Bowtie delete, painted red rotors and calipers, 1/4 window American Flags, splash guards, AEM dry panel air filter.
xstuntman is offline   Reply With Quote
Old 02-06-2020, 10:46 AM   #4
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS
I have a friend with a liberty walk widebody hellcat that’s running like 2 inch spacers, maybe more. They’re hubcentric and he hasn’t had any issues. I know he doesn’t baby that car so that certainly makes me feel more confident in them. If you’re gonna get some just make sure they’re the highest quality you can get
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears
SynergyGreenSS is offline   Reply With Quote
Old 02-06-2020, 10:55 AM   #5
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
As long as they are hubcentric, you should be good to go. It will add stress to the wheel bearings over time but not much.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 02-07-2020, 12:49 AM   #6
Athletics101
Athletics101's Avatar
Drives: 5th Gen L99
What are the spacers for? You can have your wheels made with a custom offset?
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
Athletics101 is offline   Reply With Quote
Old 02-07-2020, 07:34 AM   #7
BigJ
BigJ's Avatar
I just want to bring my rear wheels flush with the fender like they are in the front! Just need about 10 to 15mm!
Old 02-07-2020, 08:31 AM   #8
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
been running H&R 30mm hub centric on all 4 corners for 3+ yrs incl. 100+ 1/4 mi runs...still perfect.
good luck!
PEACE
Old 02-07-2020, 09:27 AM   #9
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
First determine how many mm of clearance you'll need then, then subtract that from the stud length to make sure you have at least 21mm of stud left to fully tighten lug 6/7 turns ( our std length is 28mm, our stud size is 14mm x 1.50, industry std calc for required lug tightning length for 14mm x1.5 = 21mm. I was able to get around 9 turns of the lug with a 3mm spacer I used, 100% of the torque is achieved at the 6 turn, the extra turns don't add anymore tighting/torquing)
If you don't have a least 21mm of stud length with a spacer you'll either have to add longer studs or go with an adaptor instead of spacers
THIS is where you want to get your spacers from ...custom cut from billet aluminum.
http://www.motorsport-tech.com/wheel_spacers.html
camguynj is offline   Reply With Quote
Old 02-09-2020, 02:22 AM   #10
BigJ
BigJ's Avatar
Hey thanks guys....all of this info is very helpful!!
Old 02-09-2020, 09:43 AM   #11
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
Why not get wider wheels and tires instead?
Norm
'08 GT coupe 5M (the occasional track toy)
'19 WRX 6M (the family sedan . . . seriously)
Norm Peterson is offline   Reply With Quote
Old 02-09-2020, 10:47 AM   #12
IKILLEDSUPERMAN_ZL1
For me I like the look of the factory wheels but wanted them flush with the fender and I only spent 80 bux for the spacers.
Old 02-10-2020, 08:43 PM   #13
SimpleGreen
Drives: 2015 2SS/RS
I run 1" adapters (spacers) on my 2015 Camaro with stock wheels and I have 1.5" spacers on my Jeep. Perfectly safe and reliable. Buy quality spacers and Loctite the nuts on the spacers.
2015 Camaro 2SS/RS SIM
2016 Jeep Wrangler 2DR Willys Wheeler
1993 C1500 Single Cab Stepside 5.3L LS Swap
SimpleGreen is offline   Reply With Quote
Old 02-11-2020, 08:01 AM   #14
Norm Peterson
Not at all sure I'd trust Locktite against the temperatures reached during a track session. Heat is how you're supposed to 'break' the red stuff.
Norm
