01-11-2015, 05:35 PM | #1 |
Drives: 2010 Camaro SS 6 speed Join Date: Mar 2014
Halogen headlight fuse location- non RS
can anyone tell me where the fuse is for the low-beam halogen headlights? (I have a non-RS car) 2010 SS.
In the fuse box under the hood, fuses 46 and 47 are labeled as HID headlamp left and right. (but I have halogens) 55 and 56 are labelled as High beam headlamp left and right circuits. with the headlights on, I pulled 46 and 47 and nothing happens. Is there a redundant fuse in there for DRL's that's keeping this circuit closed? I flipped on the high beams and pulled 55 and 56 and the lights went out, but I can't find the fuse that cuts out the low beams. The reason I am asking is the passenger side headlight quit working and I have replace the bulb with no result. Figured the fuse would be next thing. Can someone clue me in where the ground would be located for the passenger light? Guess that would be next to check.
Some people like to stand out in the crowd to be noticed......I like to stand back in the crowd and notice people....
2010 Camaro SS LS3 SW performance Headers, SW Retro Chambered Catback, High Flow Cats, K@N CAI, Apex Catch Can, Vmax Ported Throttle Body, Hurst Short Throw Shifter, 3.91 Gears, JRE Tune and adding to the list.. |
10-01-2019, 03:18 PM | #2 |
Drives: 2LT Join Date: Apr 2012
Has anyone figured this issue out? I have the same problem with a non-RS LLT. Also on the passenger side
10-02-2019, 08:42 AM | #3 |
376 cubic inches of fun
According to the shop manual, 46 and 47 are not used with the halogens. Instead, it's F29D in the instrument panel fuse box, rather than under-hood. However, it's just the one fuse for both sides.
10-25-2019, 04:56 AM | #4 |
Drives: bmw x6 Join Date: Oct 2019
Has anyone figured this issue out? I have the same problem with a non-RS LLT. Just let me know. Still can't fix this issue
Hello) my name is Barbara and I'm a writer. I work for Samedayessay and I really love my job and helping people.
Our writers do their work very quickly and efficiently, so each of our clients is very pleased with the result. Our goal is to free up your time so that you could spend it with benefit. Take a rest and we will do your job very well. We can also be glad to help you to make a correction of the finished text. You are not alone; most students across the globe find it difficult to submit a high-quality paper for approval. same day essay reviews |
06-06-2020, 02:42 PM | #5 |
If it is one fuse for both sides, then it's not the fuse if the one headlamp is working.
It's not the ground either, since the hi-beam works on that side. |
06-09-2020, 12:36 PM | #6 | |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
also i don't think there is even a separate low beam fuse for non-RS camaros, signal goes straight from the switch to the BCM, then to the low beams/DRLs. |
06-17-2020, 01:25 AM | #7 | |
Okay, well there are two fuses to the BCM, a 20 and a 30 AMP, F6 and F15 in the side dash fuse box. I have the schematics for the Halogen and HID. |
