![]() Drives: 2014 1LS Camaro Join Date: May 2014
Need turbo help!!!
I just finished the twin turbo install, but I am stuck on the last step. The instructions are pretty vague. Does anyone know how to install the scavenge pump drain?
Nobody with a good car needs to be justified. -Flannery O'Connor
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '13 2LT/RS Twin Turbo Join Date: Aug 2012
I'm guessing you're talking about putting that threaded fitting in the smooth hole in the back of the drivers side valve cover. I got stuck there too. You have to find the right size tap and tap that hole so you can screw the fitting into it. I wanna say it was a 1/2" x something. The instructions were kind of gauge though you're right.
You can tap the hole without removing the valve cover, I filled the hole with wheel bearing grease before I tapped it so no metal shavings would fall down into the valve cover. It worked out pretty well.
3.6L Twin Turbo V6 Garrett GT28 turbos -- Jacfab forged connecting rods -- Diamond forged pistons(10.5:1) -- Alky Control Methonal Injection -- CircleD 2E triple disc torque converter -- BMR suspension 10.75 @ 131mph |
That was a total pain in the ass.
