10-29-2017, 12:01 AM | #1 |
IG @Brian_ _Self
Drives: 2010 Camaro 2SS M6+17'Tesla Model S Join Date: Nov 2012
Needed: Pictures of YOUR rear cradle mounts/bushings!
I need some picture(s) of people’s rear cradle bushings/ rear cradle mounts. We put the ZL1 cradle into my car (from a donor vehicle that was wrecked- passenger LCA was tweaked very badly previously, we noticed this once driving my car after the install- all fixed now.)
But I’m really hoping the cradle itself isn’t tweaked any, because my cradle bushings are pretty f***ing tightened, yet the rubber contact patch on the bushing is not touching the car on any of the 4 mounting points. But I really just have a gut feeling that it isn’t how it’s supposed to be. And while it’s like this I’m afraid to really get on the accelerator or push this fancy new Z rearend to see the limits. I’m not trying to have it literally drive out from underneath me. But yeah if anyone has any pictures of how it should be I would appreciate it! Also give me some feedback!
11-01-2017, 10:58 PM | #2 |
IG @Brian_ _Self
Sorry it took a few days to post them. Family health is being priority right now. Still would like to solve this though.
11-02-2017, 07:03 AM | #3 |
Drives: 2015 Z/22 Join Date: Aug 2015
This is normal. I don't have pictures of mine (could take them but can't seem to get them off my phone ), but I do have them on a shelf as I upgraded to solid bushings, and the white rubber does not come all of the way up, flush with the metal - i.e. the rubber does not contact the subframe.
11-02-2017, 07:08 AM | #4 |
Old and New
11-05-2017, 08:41 PM | #5 |
IG @Brian_ _Self
Oh okay, Thanks guys. I've been waiting to get my alignment until I knew that was squared away.
