06-25-2018, 05:50 PM | #1 |
Drives: 02 Camaro B4C Join Date: Nov 2016
Dumb question
I purchased my 2015 used. The previous owner had programmed about 30 stations.
How do I delete his presets? I looked in the owners manual and didn't see anything. Any guidance would be appreciated. Thanks Craig
A man's garage is his castle
1969 Camaro SS 1970 Camaro SS 2002 Camaro B4C 2014 Camaro SS Dedicated Track Car 2015 Camaro 1SS 1LE 2008 HHR SS 1996 Silverado Crew Cab Long Bed Dual Rear Wheel |
06-25-2018, 08:50 PM | #2 |
Drives: 2015 2SS, 1LE, Dual Mode, Black Join Date: Aug 2014
Manually tune to the station you want and then press and HOLD the preset button down for which you want the station playing to be assigned to. It's that simple. Then do it 29 more times to replace the rest of the previous owners selections on the other buttons. Then enjoy the 1LE !
06-25-2018, 08:51 PM | #3 |
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
You may have to program over them. Meaning, pick a new channel, select the location/channel you want to replace, press and hold until you hear a beep. Not sure they can be eliminated once set.
06-26-2018, 04:02 PM | #4 |
Drives: 2011 Camaro SS/RS M6 Join Date: Oct 2010
I think you can change the number of pages of favorites if you want to lower the total number of favorites on the head unit. I think are are options of 2 - 6 pages. If you change it to 2, then change it back to 6, I think that will delete 4 pages worth.
06-26-2018, 04:12 PM | #5 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
Also, if you only use 1 list of favorites, you can use your steering wheel controls to switch between stations, and not switch between favorite lists.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
06-27-2018, 09:58 AM | #6 |
All great advise!
Thanks!
