03-02-2015, 04:35 PM | #1 |
Drives: '16 Z06/Z07, '15 Z/28,1972 Stingray Join Date: Feb 2013
Hood liner Question
I was wondering if any 1LE owners have removed the engine compartment hood liner and if it allows the heat under the hood to dissipate any faster. Can you tell the difference regarding engine sound too? Just curious.
03-02-2015, 05:03 PM | #2 |
Drives: ‘13 1LE Join Date: Jul 2013
I know one thing...taking your engine cover off and your hood insulation off will def result in more NVH.
As for temp, I've never actually measured with a device. Others will have to chime in on that one. |
03-02-2015, 06:09 PM | #3 |
03-02-2015, 06:11 PM | #4 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
NVH =Noise Vibration & Harshness
03-02-2015, 06:21 PM | #5 |
03-02-2015, 07:06 PM | #6 |
Drives: 2015 SW 1LE BA NPP Recaros Join Date: Jan 2013
I have my engine cover off and my rain tray you can see the heat pouring out of the vent
03-03-2015, 09:31 AM | #7 |
Drives: 2019 Chevy Equinox Premier AWD Join Date: Mar 2011
I have done this. I want to hear my engine and it probably makes little difference in heat but I think it is mostly done for noise cancellation. Vibration, I don't think it makes any difference. It's just kinda ugly underneath as they did not bother painting that part.
2013 AGM 1SS/1LE, NPP, Camera
(1 of 43) |
03-03-2015, 10:05 AM | #8 | |
So under the insulation the underside of the hood is not painted?
03-04-2015, 12:16 AM | #9 |
I'm almost 100% sure that it is, never saw a car in our price range with just primer showing, lol, but the real question is, like many cars today with cost cutting in mind, is it clear coated or not?
03-04-2015, 08:33 PM | #10 |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
Insulation isn't painted...its a fabric type material
UPSTATE C5 MEMBER
03-04-2015, 09:19 PM | #11 |
03-04-2015, 09:30 PM | #12 |
Haha, it's been a long night, carry on
UPSTATE C5 MEMBER
03-04-2015, 09:44 PM | #13 |
Drives: cars Join Date: May 2011
Yes its painted but it looks like a 3rd grader did it, it's not nearly as nice or polished as the rest of the bodywork. There is minimal benefit to its removal unless you provide a location for the heat to escape. Removing the engine cover and intake cover definitely help reduce heat soak since it gets it away from the engine and intake air.
03-04-2015, 10:00 PM | #14 |
When I put in my vents I noticed that the hood under the liner was painted as if just to make the paint look good at the edge of the liner. The rest was just over spray. Besides it is not very pretty under there.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears. |
