Old 12-22-2016, 12:36 AM   #1
RJT2SSRS
RJT2SSRS's Avatar
Drives: 2010 Camaro 2SS/RS
1LE hood liner.
1LE HOOD LINER WILL FIT 2010 FOR SURE $85.00 SHIPPED Brand new but does have a small crease near wind shiels side of liner. Was never used. The white looking lines on the liner come from the sun shining through the garage door windows.
2010 2SS/RS L99 CAI intake Stainless Works headers and Hi-flow cats CORSA cat back exhaust livernois motorsports dyno tune VMAX throttle body ELITE catch can GM clean side catch can 2014 lca BMR rear toe links PEDDERS Supercar suspension PEDDERS poly subframe bushings JPSS BLACK MAGIC rear sway bar DSS 1000 hp axles 1LE wheels Michelin 285/35 tires CTS-V front brake upgrade fuel rail flip heater hose relocation
RJT2SSRS is offline   Reply With Quote
Old 12-22-2016, 03:27 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Interested but not till after first of the year.
Orange Krush II
1LE Front sway bar with DSE Links, Splitter, 3.91 Gears and Axles, 14/15 Heat extractor, shocks and struts, Suede Flat bottom Steering wheel, short throw shifter with the Pegasus rear poly shifter mount, diffuser with dual mode mufflers, ZL1 Rockers, Belly Pan and pedals, Z/28 Intake, Headers, Cats,Toe Rods and UCA Bushings, 1 piece DSS Drive Shaft, C7 Z06 Vented Piston Calipers with CTS-V Rotors, PAFDT Solid Cradle bushing, 32mm JPSS Rear Bar, and Skip Shift eliminator. ASC race spec splitter and wicker. 6th Gen M017 Wheels.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
