06-04-2017, 03:44 PM | #1 |
Drives: Camaro 2ss/rs Join Date: May 2016
fitment issues with carbon creations rear diffuser!!
So im soo excited!!! I picked up my new carbon creations rear carbon fiber diffuser and it looks aggressive!!! I finally get time today to get the rear of the car all apart and start to mock things up and im noticing that the corners on the inside bends are no way going to pull up to the bumper lines!!!If I line up one side to fit the opposite corner is off 1/2 an inch??? and you cant pull the plastic bumper up to make up the difference. I've now spent hours carefully looking over what would have to be trimmed to get it closer to the bumper to spread out the area and match up the corners!!!but the inside mating flange would have to be cut off to get it in tighter which means there would be no flange left to through bolt to the bumper!!!! and it would look sooo good on the car!!! don't know what I can do and it was a 599.00 diffuser??? I expected this to fit well? Anybody here has installed one of these!!!
06-04-2017, 04:46 PM | #2 |
im soo bummed!! this would have looked great if the quality of the tooling was a better fit!! So now the rear of the car is all apart and don't know what to do???????
06-04-2017, 04:47 PM | #3 |
Drives: 2012 Ashen Gray LS3 M6 (SOLD) Join Date: Oct 2014
I have the Havoc Diffuser, mine fit great with no gaps however I notice your Carbon unit seems to be one piece.
Hopefully someone with the same model can chime in, it truly does look awesome in full Carbon, definitely would look great! Keep us posted.
2012 Camaro SS/RS LS3 6Spd (SOLD)
2011 Camaro RS 6 Spd (SOLD) 2007 Subaru WRX STI (SOLD) 1997 C5 LS1 Corvette (SOLD) 1985 C4 L98 Corvette (SOLD) 1967 Camaro RS/SS 383 sb (STOLEN) |
06-04-2017, 05:08 PM | #4 |
Drives: LT W/2LT,blue metallic Join Date: Jul 2016
unless youre wanting to ship it back for a refund you might be able to shim it and get it even,all i can suggest.
06-04-2017, 05:15 PM | #5 |
What a shame. Looks like it cured a bit off from spec.
That thing looks gorgeous. Did you have the GFX diffuser originally?
06-04-2017, 05:17 PM | #6 |
EbonyCamaro
I would send it back. And get another one
06-04-2017, 05:22 PM | #7 |
I agree. Otherwise you may be spending hundreds of dollars to get this correctly fitted.
06-04-2017, 05:23 PM | #8 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Yup, don't accept it with a fit like that. If you like the piece, send it back for another. I'd give them one more try....
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
06-04-2017, 05:57 PM | #9 |
yes this is a single part, not as defined edged like the havoc but somewhat similar. I love the havoc but they don't do carbon fiber
06-04-2017, 06:04 PM | #10 |
Had the standard ss rear diffuser, now I cant go back after looking at the possibilities of how awesome this could look if the fitment was good. its as if the second part that is glassed onto to top to make the ledge to bolt it to the inner channel of the bumper was either ground in and glassed poorly or the tooling for this was way off I guess the good part is im a hour away from carbon creations, a.k.a. " extreme dimensions" so ill call them tomorrow
06-04-2017, 06:40 PM | #11 |
Drives: 2011 Camaro 2SS/RS Join Date: Oct 2013
I'm having similar issues with my Havoc diffuser.
06-04-2017, 08:10 PM | #12 |
06-05-2017, 09:37 AM | #13 |
Instagram: Sangstah
I would contact Carbon Creations with the photos and go from there.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
06-06-2017, 04:01 PM | #14 |
Well i got down to extreme dimensions and they looked over what i had going on with the diffuser, i even took down my stock one to help line up and compare. So they went through and got me a clean one that i hope to be a better fit praying!!!!ill find out this week
