11-07-2018, 04:35 PM | #1 |
Drives: 2010 Camaro SS A6 Join Date: Oct 2018
Comparison - battery/underdrive pulley
Quick question - $200-$300 left for mods. I'm looking at the Powerbond UDP or the Braille B2015 lightweight racing battery.
Looks like the UDP gives 5+hp/6+Tq to the rear wheels The Braille battery would save almost 30lbs in weight I currently have CAI/Hi-Flow Cats/Flowmaster Outlaws/Custom Tune/Drag Radials |
11-07-2018, 05:13 PM | #2 | |
Drives: 2015 1LE Join Date: Oct 2015
11-07-2018, 05:50 PM | #3 |
I hear ya. It wouldn't be for a daily driver. Just an occasional driver and going to the strip over the summer some. I would keep the stock battery though for resale and then resale the Braille Battery to the Harley guys.
11-07-2018, 07:12 PM | #4 |
UDP all the way!
11-07-2018, 09:03 PM | #5 |
A lot of people tried the lightweight batteries on daily’s and found it to be a pain.. great for track days only honestly. I’d go with the UDP if I had to choose.
Car mods: never enough!
11-08-2018, 07:24 AM | #6 |
old school chevy rodder
UDP a lot of fluff.....I use the Fluidampr because it has real damage limiting qualities, the deal is if its cheap its a POS like the stock pulley.. not a dampener does not stop harmful vibrations.... and I use a UDP only for the alternator...since my idle is 950 its no drain, and frankly they make like Zero for HP those claims...are just that claims . Use stock type batteries, there are better things to spend money on. Since you have no long tubes, you should save for them not just high flows unless your smog requires..... your not cammed which has it requirements for maintenance over time. You could with that money say buy some trailing arms from BMR that would be the best use of that money, maybe a ported TB over time. Good luck.
11-08-2018, 08:42 AM | #7 |
Although not a direct replacement, when I swap out the battery in my Camaro I am goint to put in an Optima redtop 35 which is 31.7 lbs. You save 15 lbs over the factory battery and it will last. Compromise.
11-08-2018, 11:19 AM | #8 |
I have used my Shoria lithium battery since april with zero issues daily driving. In my opinion using a light weigh battery in a 5th gen is the last mod as the weight is where you want it for ballast. As far as under drive pulley I would stick to ATI 10%. I use a 25% for clearance issues as i have an EWP with no idler pulley and use no belt tensioners.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85 Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE 10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake Best 1/8 6.80@105.75 Best MPH 134.82 |
11-08-2018, 11:28 AM | #9 | |
Drives: 2010 SS L99 Join Date: Sep 2018
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
11-08-2018, 04:13 PM | #10 |
Thanks guys. I'm most likely gonna go with the BMR Trailing Arms with Poly Bushings. Sometimes it's really easy to get wrapped up in engine mods and forget about putting that power to the ground.
Nice price. I've never installed them before, but it looks like a straightforward install |
11-08-2018, 07:04 PM | #11 | |
11-09-2018, 07:39 AM | #12 |
Eliminate wheel hop for the future build also smart move, nothing like saving the stock axles......LOL I am still going with stock axles...……. and they are only rated like stock HP....
