10-03-2017, 08:21 PM | #1 |
Drives: 2011 camaro ss Join Date: Sep 2017
Silly question
Never owned a convertible up till now but i know of the rattles and shakes of a camaro.
Anyways does anyone's camaro give a slight vibrate doing 80-85? Nothing bad but its noticeable. Car stays straight driving and thought maybe tires need balance, but figure I'd get some input. |
10-03-2017, 09:52 PM | #2 |
Lifetime Philly Fan
Drives: 2015 Spring Edition 2SS M-6 Join Date: Mar 2012
No vibration at high speeds what so ever on mine.
2015 Green Flash, Delivered 4/10/15
CAI, NPP Exhaust, Short-throw shifter BBK LT HEADERS 1 7/8” Tune by DynoSteve via SCTx4 Tuner One of 82 GF Ragtops built in '15 out of 811 Total [/SIZE] |
10-05-2017, 07:05 PM | #3 |
Kept The Faith
Drives: 2011 Camaro SS Convertible Join Date: Jan 2007
Agreed, have the balance checked.
2011 Vert - 2SS/RS 6spd Triple Black
10-06-2017, 02:10 PM | #4 |
Drives: 2024Camaro 2SS CE Convertible Join Date: Jul 2013
Yeah, what daddySS said
10-06-2017, 04:30 PM | #5 |
Drives: 2013 SS Convertible, ThumperII Join Date: Nov 2016
We don't have a vibration, get the tires and balance checked
10-13-2017, 07:47 PM | #6 |
Drives: '14 2SS/RS Vert 6M/KTU/NPP/DTA/ARH Join Date: Jan 2014
One can induce a mild convertible "cowl shake" going over bumps at speed but I'd agree with the others if your vibration is on a smooth road.
Consensus is, by definition, a lack of leadership.
10-16-2017, 11:57 PM | #7 |
Drives: Camaro 2LT RS Convertible Join Date: Aug 2014
Yep, there should be no shakes at that speed, something needs an adjustment
03-02-2018, 09:25 AM | #8 |
Drives: 1991 Z/28 Convertible Join Date: Feb 2018
I had a 1991 Z/28 that was horrible for vibration.
03-02-2018, 05:12 PM | #9 |
No vibe here. Check tires for balance and chopped tread at outer edges.
03-03-2018, 08:29 AM | #10 |
Drives: 2014 Red Hot ZL1 Vert. M6. Join Date: Jan 2014
Not a bit.
03-10-2018, 07:33 AM | #11 |
Drives: 2019 2SS Convertible Camaro Join Date: Mar 2012
Tire balance and roundness first, then shocks if you have high miles. The only rattle I had (which drone me crazy) was with the long plastic piece across the interior of the top that the top unlock handle folds up into. That piece is held in with screws and inserts and when the inserts crack out the plastic rattles. You can put a little pressure on it or pull on it a bit when you hear the rattle to see if it stops. Luckily it’s a $45 part and 20 mins to replace, there is a thread on the site somewhere. Congrats on the new vert!
\(^^^)/ <--A Smile From He11
Escort 360 MAXX w/DIYGen5 hardwire Harness K&N AirCharger Cold Air Intake Sound Tube Delete |
