06-25-2018, 07:15 PM | #1 |
4.10 Motive 218mm Diff
Looking to trade my 4.10 diff for a 3.91 diff with factory bushings. I'm looking for a low mileage 3.91 with factory posi not abused. You will get a diff with factory bushings and or Hendrix off-set bushings if you prefer. Motive 4.10 REM polished, Tru-Trac REM polished and bearings have 700 miles on it from new. Basically all but the case is brand new. I realize I'm trading for something of lesser value but I need to experiment and willing to deal.
Pm me if interested.
06-26-2018, 11:12 AM | #2 |
Drives: 2010 Camaro 2SS/RS ABM 6M Join Date: Jul 2017
Damn...I just put in a 3.91 rear end (that had your old 3.91 gears inside it, I believe). If I hadn't JUST installed it this weekend, Id have probably jumped on this. Could have made your stuff go full-circle lol. Don't feel inclined to do the swap again anytime soon though
Car seems to like 3.91 but I think it would have liked 4.10s even better. Oh well, this is probably better for my down the road boost anyhow
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
06-26-2018, 01:03 PM | #3 |
GPI Sales Consultant
Darn you - I need a rear end 2 weeks ago! I couldn't have given you a 3.91 - but I sure would have paid cash for that! The M6 guys with 3.91's and big nasty cam's should be lining up to make this trade with you.
Got a question about a GPI product? Feel free to shoot me a message! |
06-26-2018, 01:05 PM | #4 |
Damn you are too far and I have a 3.91 that I am going to want to switch down the line but I need something beefier to hold that power that I want to add.
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries) Procharger D1x with a 3.85 pulley ID1050x Injectors Flex Fuel Sensor Monster LT1 Twin Disk Clutch Holley Sniper Efi Intake Manifold NW 103mm Boosted TB 747rwhp at 12psi on E85 |
06-26-2018, 01:12 PM | #5 |
Not too many options for a beefy 4.10 unless you want to solid rear axle, or one of the $5k+ IRS setups from Strange or Lingenfelter. The LPW cover, if you haven't looked into that already, is a good piece of insurance. It has a pair of bolts that tighten down externally onto the ring gear caps, which helps them hold the ring gear in place. Additionally, it helps the aluminum housing better hold it's shape than the stock cover.
06-26-2018, 01:59 PM | #6 | |
I know I would need to get a new driveshaft as well. I am in the process to get a 416ci forged stroker Lets see and good luck with sale OP
Specs
06-26-2018, 09:01 PM | #7 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
huh...
06-27-2018, 08:32 AM | #8 |
07-16-2018, 11:13 PM | #9 |
Soon as my ZL1 3.73 rear sells I'll call you!
Anybody in here interested? |
07-29-2018, 10:52 AM | #10 |
Drives: 2010 ssrs Join Date: Mar 2016
Still available I have set 3.91 In box waiting to be installed
