Solo Performance
Old 05-23-2011, 12:14 PM   #1
Brett@XPR
Drives: 02 Camaro Race Car
Gauges
I am looking for a way to mount some aftermarket 2 1/16" gauges in a 2010 SS......Are there any pillar or dash mounts out there for a boost gauge and A/F gauge?
Brett@XPR is offline   Reply With Quote
Old 05-23-2011, 12:36 PM   #2
Kwik
Drives: car
Try Feslers.
Upgrades to suspension, brakes, motor and appearance. 482.7 RWHP- 434.2 RWT - All motor.
Kwik is offline   Reply With Quote
Old 05-23-2011, 12:46 PM   #3
Cincy10SSRS
Cincy10SSRS's Avatar
Drives: 2010 2SS RS M6
Not a pillar or dash mount but I might end up getting this and install an Aeroforce Interceptor scan gauge and maybe a trans temp guage.
http://www.pfyc.com/pc/CA2030/CAINT/...Gauge+Pod.html
Cincy10SSRS is offline   Reply With Quote
Old 05-23-2011, 01:00 PM   #4
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
I got mine from Stillen. Give them a call.
Where would you even mount that?
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 05-23-2011, 01:09 PM   #5
Cincy10SSRS
Umm, same place the four-guage cluster goes.
Old 05-23-2011, 01:23 PM   #6
IamJacksCamaro
IamJacksCamaro's Avatar
Drives: Camaro LS M6, Fiero, Ford F100
Originally Posted by Kwik View Post
Try Feslers.
I can't see your gauges in the attached picture.
IamJacksCamaro is offline   Reply With Quote
Old 05-23-2011, 02:49 PM   #7
lexlueger
lexlueger's Avatar
Oh...I already have those. GL with the install.
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 05-23-2011, 03:22 PM   #8
Kwik
Drives: car
I don't have a gauge mount. I have the GM 4 gauge cluster. I mentioneds Feslers because I know they have a dual gauge pillar mount. I believe the website is feslersbuilt, but not sure. Hope that helps.
Old 05-23-2011, 03:40 PM   #9
Autobots
Roll out!
Autobots's Avatar
Drives: 2010 ss/rs ls3
The dask speaker spot on top of the dash would be a cool spot
Autobots is offline   Reply With Quote
Old 05-23-2011, 05:36 PM   #10
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
+1 for Fessler!
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 05-23-2011, 05:44 PM   #11
010 Camaro SS
010 Camaro SS's Avatar
Drives: 2010 Camaro SS 2SS
Got the Fesler Dual Gauge pod...Nice fit...
010 Camaro SS is offline   Reply With Quote
Old 05-23-2011, 05:48 PM   #12
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
I just put in a dual gauge pod for the A-pillar in my 2SS with a boost and A/F gauges. IPS Motorsports now makes their own. I got one of the first ones. The fit and finish are better than any other I've seen. I'm VERY happy with it.
STRI Gauges - Innovate Motorsports Gauges and Zenesis Alarms @ Import Image!! ImportImage Audio / Visual / Electronics/ Gauges / Nav 83 11-04-2011 05:03 PM
Camaro OBDII Aeroforce Scan Gauges!!! Meister@Torq Audio / Visual / Electronics/ Gauges / Nav 7 06-28-2011 12:19 PM
Replace 4 pack gauges with custom Autometer type gauges NVMYSS Cosmetics and Lighting Modification Discussions 1 04-27-2011 05:04 PM
Additional gauges LoneCynic 5th Gen Camaro SS LS LT General Discussions 5 08-05-2010 11:51 AM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
