08-08-2018, 10:31 PM | #1 |
Drives: 2013 Camaro 2SS Join Date: Oct 2017
Do I need to replace both rear tires?
Ran over a bolt and replaced one rear tire, 275/40/20. Measured tread difference when I got home, New tire has 4 or 5/32 more tread.
I’d rather not replace the other tire. Will I cause any stress on the rear differential? |
08-08-2018, 10:35 PM | #2 |
Cyber/orange10
Handling and braking will be compromised with that......
08-08-2018, 11:07 PM | #3 |
Drives: Miss Con Ception Join Date: Aug 2016
I don't remember if the new Pirellis begin with 8 or 10/32.
A tire is considered worn out at 2/32 so if you are at 3/32 it's not going to waste much to pair them up equally. Some shops can sell used tires and will give you a few dollars if there is any life left to them. BTW, the life span on tires is considered 5 years...
2011 1SS/RS LS3 CGM
08-09-2018, 06:02 AM | #4 |
I double checked my tires.
New tire is about 11/32, old tire is about 6/32. |
08-11-2018, 08:24 PM | #5 |
You are right. Went for a drive today and handling is significantly off. Left bias on moderate acceleration, immediate right bias when I change gears.
Time for another tire. |
