08-10-2018, 11:25 AM | #1 |
Drives: Black camaro 2ss 45th Join Date: Jan 2018
Recommend me a longer stud
I’m gunna need to run 10mm spacers on the fronts for my new rim set up. I got the spacers covered. I know to go hub centric and all that. My question is studs. I know for a fact that the factory studs will not be long enough. Can someone recommend a part number or the proper length stud I would need for a 10mm spacer?
I’ve read some guys have used 2009 and up ctsv studs cause they’re 7mm longer. Not sure if there’s a better option out there Thanks guys |
08-10-2018, 03:31 PM | #2 |
Dorman 610-428 is 7mm longer than stock studs and what I went with in case anyone needs an answer to this in the future
08-10-2018, 06:02 PM | #3 |
Studs
I have some.that I had for mine.
08-10-2018, 06:12 PM | #4 |
Drives: '14 1LE Join Date: Nov 2013
08-10-2018, 06:20 PM | #5 |
08-10-2018, 06:21 PM | #6 | |
