Old 11-10-2018, 11:37 PM   #1
Bandit63
Bandit63's Avatar
Drives: 2011 Camaro SS
Nitrous guys?
How are you nitrous guy retarding timing? I’m looking at getting a lnc-2000. Is this the best way to go?
MRR M228 Wheels, Circle D 3200 Stall, 3.91 Gear, Texas Speed VVT 3.2 Cam, CHE Rocker Arm Bushings, Texas Speed Headers, No Cats
Bandit63 is offline   Reply With Quote
Old 11-11-2018, 06:46 AM   #2
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
Mine is done through the tune. Dynosteve @ RDP sends me the tune via the SCTX4 that I bought from him a couple years ago.
The only thing needed after installation is to record a pass at the drag strip for fine tuning. Aside from that you just need a colder spark plug based upon what size shot you run. I run a 1 step colder plug.
A catch can is also a good idea, I had one before nitrous and you'll get more blow by
with nitrous.
A good bottle pressure gauge is also beneficial, my ZEX kit works perfectly @ 900-950 PSI.
I run a 125 shot.
I called the closest DYNO shop in my area for a nitrous tune just to see what the cost was.....$600.....the SCTX4 from Steve is around $400 or so.....I got mine a little cheaper because I bought a kit......plus with the SCTX4 from Steve you get free tunes for life.
Steve always gets revised tunes after I send a datalog to him back to me in 24 hours or less. Great customer service.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles.
Joe M 2012 2SS is offline   Reply With Quote
Old 11-11-2018, 11:11 AM   #3
Bandit63
Bandit63's Avatar
I was wanting to go with something so I wouldn’t have to swap out tunes and I’ve already paid for dyno tune using hptunes.
Old 11-11-2018, 11:35 AM   #4
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
My tuner was able to set up my tune safe for 100hp shot. No detonation or lean conditions. Not sure how much you plan on spraying... I made 524 on motor and 620 on spray... same tune
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 11-11-2018, 05:38 PM   #5
Joe M 2012 2SS
Drives: 2012 2SS
I don't swap out tunes. I believe my timing was retarded 5 degrees for the 125 shot. The car drives fine with the nitrous tune on the street.
Yes...…. you will not have maximum performance on the street due to the timing being retarded, but your not doing hard launches, WOT pulls, or using nitrous on the street (at least I hope your not), so the loss from the timing being retarded won't make any difference for normal driving.
Old 11-11-2018, 06:07 PM   #6
Clarkstar
Clarkstar's Avatar
I do lots of WOT pulls using nitrous on the street.... what's wrong with that?
Old 11-11-2018, 07:01 PM   #7
Joe M 2012 2SS
Drives: 2012 2SS
Using nitrous on the street is against the law. You can have a bottle in your car, but it cannot be connected.
It's also very dangerous. I did try mine out on the street when I first got it on a road with no traffic, and the rear tires (used my MT ET Street R Drag Radials) broke loose quickly getting the car a little sideways when activating it at 25 mph, 35,mph, and 45mph. I quickly let out of it each time. I only use it now where it is intended and legal to use, at the drag strip.
Old 11-11-2018, 07:15 PM   #8
Clarkstar
Clarkstar's Avatar
I also have drag radials. I have a window switch, on at 3000rpm, off at 6800, shift light comes on at 6900. I can feel the tires spin a tad when it comes on... but it hooks up and pulls hard.
Old 11-11-2018, 07:17 PM   #9
Clarkstar
Clarkstar's Avatar
Watch "3" spintech in car" on YouTube
https://youtu.be/9F0xdhSzrAM
For your viewing pleasure...
Old 11-11-2018, 07:41 PM   #10
Joe M 2012 2SS
Drives: 2012 2SS
I have a L99 with a 3200 stall, no window switch, it activates at WOT. Impossible to make it hook up on a non-prepped surface with nitrous activated.
Regardless of driving a manual...automatic.....stock converter...stalled converter.....window switch...no window switch....it's still illegal to use on the street.
If you don't believe me call your local highway patrol....city or county police department. They will tell you the same thing....it's not street legal.
There isn't a single situation in which I need nitrous when driving on public streets anyway.
I don't want to jack Bandit's thread about the law concerning nitrous use on the street though......his question was what to do about the timing retard when not using nitrous.
I have daily driven my car for over a year with the nitrous tune on it with no issues at all from the timing retard.
Old 11-11-2018, 07:47 PM   #11
Clarkstar
Clarkstar's Avatar
Relax dude, I never said it was legal... I think everyone knows its not. Just like speeding, not wearing your seat belt, turning with out a directional... and on and on...
Old 11-11-2018, 08:01 PM   #12
Joe M 2012 2SS
Drives: 2012 2SS
I am completely relaxed. You made this response to my reply...…..
I simply responded with the truth about using nitrous on public streets. If you choose to do it, that is your decision.
I think it would be a good idea to get ...….Bandit created this thread to get replies from nitrous users on what to do about the timing retard from the nitrous tune when not using it. I haven't had any issues at all with it on the street, and I don't believe he will either.
Old 11-11-2018, 11:38 PM   #13
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
tag into the iat sensor using a relay that will ground it when the nitrous is armed. set these iat values for something like -100 degrees. something that can never be achieved. pull your xx degrees out and there you have it. n/a timing and nitrous timing, all one tune
ttshovel is offline   Reply With Quote
Old 11-12-2018, 09:01 PM   #14
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
Lnc2000
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
