02-10-2021, 09:50 AM | #1 |
Why I built a stroker
So that's what I hurt in my engine..... I was wondering.....lol
02-10-2021, 09:53 AM | #2 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Just jb weld it back on and send it
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
02-10-2021, 10:00 AM | #3 |
Clean escape lol
02-10-2021, 01:22 PM | #4 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Looks like someone got hungry
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
02-10-2021, 01:51 PM | #5 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
What caused that?
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
02-10-2021, 03:50 PM | #6 |
Drives: 2017 Silverado Join Date: Mar 2017
I have no idea how that head isn't hurt. you got lucky there. chamber should be beat to shit for the size of the chunk that came off.
'14 2SS A6, CAI, 2" TSP Headers and tune: SOLD
'13 SS @ Burkhart Chassis |
02-10-2021, 06:42 PM | #7 |
Not sure but I'll take it lol.
02-10-2021, 06:56 PM | #8 |
Drives: 2010 1SS Join Date: Aug 2015
You better go out and get some lotto tickets if you didn't already!
2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
02-10-2021, 07:44 PM | #9 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Damn thats crazy man
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
02-11-2021, 02:15 AM | #10 |
What pistons did you have in that?
02-11-2021, 04:46 AM | #11 |
Drives: Ashen grey, 1SS, L99 Join Date: Aug 2016
It was a stock bottom end so the stock LS3 flattops?
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
02-11-2021, 05:41 AM | #12 |
It don’t come easy.
Where did you find the broken piece, or didn’t you?
02-11-2021, 05:47 AM | #13 |
dang.. how did that get out without any evidence? lol
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
02-11-2021, 08:23 AM | #14 |
Yeah, I was asking because the flycutting looked nice and clean if stockers.
Edit - just found a borescope pic of one of my LS3 pistons before I had it rebuilt. Looks to be the LS3 flat top like you said, numbers match mine. 81222B A7...It's crazy to see how little material there is between the crown and first ring land. If you look you can see the edge of the broken off piece perfectly follows the fly cut, which I guess makes sense.
