12-05-2019, 08:56 AM | #1 |
Drives: Camaro 2ss Join Date: Nov 2019
Do u guys recommend putting rtv on the heads
Hey just need your guys opinions...I've got the parts in for the 3-4 time to put the head bck on, and was wondering wether u guys recommend using rtv on the head gasket or not? My last thread couple peeps said it's recommended on all 4 corners so was hoping I could get sum advice, thnx.
12-05-2019, 09:53 AM | #2 |
15 Year LS1Tech Member
Drives: 2010 ss 391ci LS3 Join Date: Apr 2017
I've also herd the same from some "old school" guys. I've never had a problem NOT using it. Only way I would even consider is is if there were a defect where the head seals like a deep scratch or something. As long as the heads/block have a clean surface, not needed.
GJDM |
12-05-2019, 10:04 AM | #3 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
Since you have had issues with leaks. I would probably do it. It is against what I would ever do. I have never put RTV on a head gasket personally. Have you sent the heads out to the machine shop to be checked? If there is a hairline crack the RTV won't be any help.
12-05-2019, 10:44 AM | #4 |
Psycho on day pass
Drives: 2010 yellow 1ss m6 -GM tech Join Date: Apr 2009
NEVER use RTV on head gaskets.
I've only used RTV to repair corroded head surfaces so it sits flat on the gasket. Make sure the surfaces are clean and new looking and dry. The gasket crushes down to take up imperfections in material. Dowels in the block keep the gasket from moving. Get the heads checked and plained if its required. Clean out your head bolt bores so there isnt any fluid or debris in them and use NEW stretch bolts. Putting any type of material on the head gasket causes a high spot and will affect torque values. Just because the "Old Dogs" use to do it doesnt mean it was correct. |
12-05-2019, 01:15 PM | #5 |
Drives: 2014 Camaro 2SS Join Date: Feb 2015
Do not use rtv on head gaskets
12-05-2019, 01:41 PM | #6 |
Are the '4 corners' that are being referenced, the 4 corners that are formed between the heads and intake manifold at the front and rear of the block? That's the only 4 corners that I would ever consider putting RTV on.....
12-05-2019, 03:33 PM | #7 |
Ponies are for girls
I've never used on any of my engine builds. As long as you torque all 3 times correctly, you'll be fine.
H&R 1.8/1.7” drop, Overkill 80mm + intake ported by AFS, 1" insulator MACE, Accel Super Coils, THR cai, JET MAF sensor, Hurst shifter handle, GPP strut tower brace, CI ice cube tray hood vents (functional) @SemperFiCamaro
12-05-2019, 03:56 PM | #8 |
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
I have done several engine builds over the years, have used RTV on a head gasket; never had any leak.
12-05-2019, 04:41 PM | #9 |
Just chuck the gasket. Use RTV, might as well. It will fix all your problems....
12-06-2019, 12:09 PM | #10 | |
12-06-2019, 12:15 PM | #11 | |
12-06-2019, 06:10 PM | #12 |
Drives: ABM #93 Join Date: Oct 2018
Definitely wouldn’t recommend rtv on the heads. Glad you figured it out.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. Last edited by Aqua Blue RS/SS; 12-07-2019 at 09:51 AM. |
12-06-2019, 10:21 PM | #13 |
Only place I am using RTV on an LS is the front and rear covers where they meet the pan. Or if I had my heads ported I would use some on the rocker bolts.
If I was concerned about my heads sealing I would likely get them checked and resurfaced. It really isn't very expensive for just a clean up. My thoughts are, if you are needing RTV, you aren't square.
12-07-2019, 07:13 AM | #14 |
I recently read where the silicon from the RTV can screw up an engine. People put too much and then it ends up getting into the engine and plugging up oil passages ect.
https://youtu.be/eHEcf0itBuE
Life is short, drive it like you stole it! |
