02-01-2015, 03:05 PM | #1 |
Go fast, please.
Venting crankcase pressure?
Just was reading a thread where a guy possibly blew a seal due to too much crankcase pressure. I was just wondering with my upcoming mods (28% over drive lower pulley, stainless power headers, 1 step colder plugs, and tune) if I will want to do anything special for venting excess crankcase pressure. I already have an Apex catch can which I read helps, but is there anything else I should consider to avoid these kind of problems?
02-01-2015, 03:38 PM | #2 |
Drives: '21 ZLE A10 Join Date: May 2012
a breather in place of the oil cap helps. You get a little spatter of oil but it is much better than a rear main leak. Some catch cans have a breather on top of them. Check out Smitty's setup as he posted some pics of his underhood.
02-01-2015, 04:18 PM | #3 |
Go fast, please.
What does this breather look like? Also, I can't find anything from a smitty on this site..
02-01-2015, 05:01 PM | #4 |
I ran a breather oil cap, but got tired of it spraying oil everywhere. Swapped to a very nice mighty mouse catch can. I've had elite, RX and a few others and MM is hands down the nicest I've had. You can run their race can, draft can, or PCV can.
Nick
Corvette Z06 -1200ish rwhp |
02-01-2015, 05:13 PM | #5 |
Go fast, please.
Is it possible to add a breather on the side of the Apex catchcan?
02-01-2015, 05:25 PM | #6 |
Drives: 2013 ZL1 Camaro 2000 SLP Camaro Join Date: Oct 2012
If you look at my albums on here there are some pics. If you want just pm and I can send you pics of the whole setup
2013 ZL1 748rwhp & 733 rwtq ( 93 tune )
02-01-2015, 05:26 PM | #7 |
Go fast, please.
02-01-2015, 05:54 PM | #8 |
02-01-2015, 08:31 PM | #9 |
Does anyone know if it be possible to use the two side ports on the E2 catch can for the inlet and outlet, then use the top port for a vent ?
02-01-2015, 09:26 PM | #10 |
'It's an experiment'
I have the Mightmouse Breather on mine:
-Don |
02-01-2015, 09:31 PM | #11 |
02-01-2015, 09:36 PM | #12 |
None so far. I just drove 600 miles and not a drop. I don't have the catch can yet but will be putting that on.
I checked it along the way, and not a drop of oil so far. I'll check it again on the way back and let you know if I see anything. So far, looks good... -Don |
02-01-2015, 09:43 PM | #13 | |
I do have a catch can and wanted to use both as I am running around 14 psi of boost. I really like the looks of the vent on Smittys car. Would like to be able to go this route. |
02-01-2015, 10:09 PM | #14 |
I also have the mightmouse pcv catch can but it is not here yet. Have the gen5 mount. Once I get it, I'll post what it looks like...
