05-30-2014, 06:16 PM | #1 |
Drives: 2013 Camaro ZL1 Coupe IOM Join Date: Jul 2013
Installed Vmax tb and catch can went for ride = problems
I have a 13 zl1 m6 already had a rotofab on installed and the exhaust fuse pulled installed Vmax lsa tb and apex catch can started car up last night the car surged for about two min. Pulled 5 and 20 fuse all night. Went for ride today from first to second I laid into easy went to third it sounded like I ran something over then went into engine power down mode. I limped to side of road turned car off. Waited a few minutes then started it up and held the traction control button down it turned off the engine power down mode. I drove it home slow.
I don't know whats going on? Any help would be great!
2013 Camaro ZL-1 #3553, IOM, Roto-Fab Intake, Vmax Ported TB, Apex Catch Can
05-30-2014, 06:18 PM | #2 |
I do have a sel light on now as well
05-30-2014, 06:25 PM | #3 |
Drives: 2013 Camaro 2SS/RS M6 Join Date: Feb 2013
Did you make sure all your sensor wire(s) were plugged back in?
2013 Black / Black Camaro 2SS/RS M6 w/Magnuson TVS2300, ZL1 Fuelpump / ADM FPCM, NPP Exhaust, Cold Air Inductions CAI w/ Scoop, Elite Engineering Catch Can, VMAX Ported TB, OEM 1LE Front Splitter, AAC Ghosted Side Markers, Dropped on BMR Split Drop Springs Build#24869 |
05-30-2014, 06:28 PM | #4 |
That I can tell they all seem tight
05-30-2014, 06:49 PM | #5 |
Drives: 2013 ZL1 A6 #7860 Join Date: Apr 2014
It is so easy to swap, I would swap the stock TB back in and see what happens? Maybe the vmax was bad? (doubt it but maybe).
My car surged and ran and idled a little odd when I installed the vmax but after about 20 minutes it died down and runs great. very responsive throttle. |
05-30-2014, 06:57 PM | #6 |
How tight do you put the tb bolts on. I had torqued mine to 9ft lbs and I can't see the green gasket. I know they were very easy to back off from the factory. I don't remember if I could see the gasket then.
Could this be the problem?
05-30-2014, 08:01 PM | #7 |
Stock lsa Vmax tb
05-30-2014, 08:03 PM | #8 |
1st Civ. Div.
Drives: Camaroless for now...RIP "Big SexZ" Join Date: Dec 2007
Did you pull the negative cable on the battery before doing your install? This helps the computer learn the parameters of your new setup. Like others have said, make sure all your fittings are secure and that your MAF sensor is facing the proper direction.
Edit: I now see that you already had your cai intake before doing this mod.
Swift....Silent....Deadly
05-30-2014, 08:06 PM | #9 |
1st Civ. Div.
The negative cable pull was part of my CAI install instructions.
05-30-2014, 08:20 PM | #10 |
Drives: '21 ZLE A10 Join Date: May 2012
make sure the throttle body is evenly torqued to a firm 1/4" ratchet torque...10ft/lbs ish. I put a little lube on the gasket to help the seal...very thin amount. Double check the intake tube attached to the TB itself...you could have pinched it off and a huge air leak happens. Make sure the MAF sensor is oriented the the correct direction marked "flow" with an arrow. Double check the plug is clicked into the MAF well. Unplug it and recheck. What is your code from the CEL?
05-30-2014, 08:43 PM | #11 |
I don't know what the code is yet.
05-30-2014, 08:50 PM | #12 |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
Unhook catch can and put hoses back to stock, could be a vacuum leak or hose issue with the can.
05-30-2014, 10:58 PM | #13 |
1st Civ. Div.
Did you put in the supplied plug on the optional second side outlet on the Apex catch can? It will run rough and surge but you should also be able to hear the air escaping as in an air leak if you didn't.
05-31-2014, 05:14 AM | #14 |
call Onstar and get them to scan the car! They will do it for you. Tell them to give you the code.
