07-02-2017, 07:22 PM | #1 |
Drives: 2010 Inferno Orange 2SS Camaro M6 Join Date: Jun 2012
Pegasus CNC Toe Arms
Hey all. Anyone here using Pegasus CNC's (2012LS3VERT) stainless toe arms? If so, I have a question for you. Let me know. Thanks.
LS3 | Magnacharger 2300 supercharger | ZL1 fuel pump | FAST 65lb injectors | 3.4" pulley | JRE belt tensioner | Elite RX clean/dirty side catch can system | CAI | Magnaflow Exhaust | Monster Clutch LT-1S twin disc | Tick remote clutch bleeder | DSS Carbon Fiber DS | DSS 9" rear with 3:70 Wavetrack gears | DSS 1400HP axles | Pegasus CNC stainless steel trailing/tow arms/solid subframe connectors | Hurst short throw | JBA mid pipes | Bosch wide-band O2 sensor | Innovate Motorsports LC02 wide band controller | Innovate Motorsports Air/Fuel/boost gauges | Baron Concepts center speaker gauge pod
07-02-2017, 07:57 PM | #2 |
CAR-DASHIAN
Drives: 2015 Ashen Gray Metallic 2SS/RS L99 Join Date: Nov 2015
I do have their solid cradle bushings so yes, I am hypocriticing much right now...
As far as the rest of the suspension, I have taken Justice Pete's advice... use the Z/28 parts and his Front Radius Arm insert bushings. I have broken 1.02g with these parts and his Aggressive Street Alignment. Parts in my Sig - just sayin' PS These parts give fantastic handling and still maintain the crush features so if you have a bad day, you will replace a few hundred dollars of parts as opposed to a few thousand dollars getting your frame straightened. Check out Justice Pete's "The Book of 5th Gens suspension guide. Hth
PERFORMANCE: ColdAirInductions CAI, ADM Race Scoop, Cordes Performance Racing Ported TB/IM/Custom VVT Cam, WFO Milled Heads, Stainless Power 1 7/8" LT/3" HFCs, JBA 3" Comp. Cat-Back, Taylor 10.4mm Plug Wires, Tim King Performance Stage 3 6L80, Circle D Billet 3600 Stall, Nic D ECM/TCM Tune, - 458rwhp/413rwtq (prior to PIM), Forgestar F14 (F)18" / (R)17" Rims.
SUSPENSION: Z/28 Rear UCA Bushings, Carlyle Racing LCA/TA, BMR Adj. Toe Rods/Xtreme Anti-Roll Bar, Justice Pete Castor Locks/Radius Rod Inserts, Pegasus Billet Rear Cradle Bushings, Mickey Thompson Street SS II 305/45/17 tires. |
07-02-2017, 08:53 PM | #3 | |
07-02-2017, 10:22 PM | #4 |
CAR-DASHIAN
Sorry Bro, was just trying to help.
Hope you get a better answer to your question
07-03-2017, 08:45 AM | #5 |
I appreciate your response! Thanks for helping out.
