Old 07-27-2017, 09:19 AM   #1
enroberts
Drives: 2010 Inferno Orange 2SS Camaro M6
Broken TR6060
Hey all. It finally happened....the main shaft of my early VIN 2010 tr6060 snapped clear off. Can anyone point me in the right direction for a transmission replacement? I'd like to find something used but want to be sure I'm getting one that won't break again. Putting down ~600rwhp. I know GM knew this main shaft was an issue but there's nothing they'll do for me now! I also have heard a 2011+ 6060 had this issue corrected but want to know what to look for. Thanks!
LS3 | Magnacharger 2300 supercharger | ZL1 fuel pump | FAST 65lb injectors | 3.4" pulley | JRE belt tensioner | Elite RX clean/dirty side catch can system | CAI | Magnaflow Exhaust | Monster Clutch LT-1S twin disc | Tick remote clutch bleeder | DSS Carbon Fiber DS | DSS 9" rear with 3:70 Wavetrack gears | DSS 1400HP axles | Pegasus CNC stainless steel trailing/tow arms/solid subframe connectors | Hurst short throw | JBA mid pipes | Bosch wide-band O2 sensor | Innovate Motorsports LC02 wide band controller | Innovate Motorsports Air/Fuel/boost gauges | Baron Concepts center speaker gauge pod
enroberts is offline   Reply With Quote
Old 07-27-2017, 09:41 AM   #2
Stingr69
'69 Owned Since '79
Stingr69's Avatar
You could always rebuild it with updated output shaft and add rear support bearing. Bearing was taken out of the design before production started to save money. Easy mod.
Old 07-27-2017, 09:45 AM   #3
enroberts
Wouldn't it be cheaper to swap for a trans that they added the bearing back in or did they never add it back in? I have quotes for over 3k to rebuild.
Old 07-27-2017, 09:45 AM   #4
608RS
608RS's Avatar
Drives: 2015 2ss
GEn5DIY has some leftover z/28 transmissions, maybe this is an option?
http://www.gen5diy.com/exhaust/Z28-T...-Transmission/
2015 Camaro 2ss, NicKey Performance built/tuned
608RS is offline   Reply With Quote
Old 07-27-2017, 09:48 AM   #5
enroberts
Nice. Thanks. Z28 6060 would bolt right up and my DSS one piece would work right?
Old 07-27-2017, 09:52 AM   #6
Audio_Rookie
Drives: 2010 camaro, 1971 datsun 240z
I just bought a brand new mm6 tranny from gm for about $2500 US. This is the stock tranny from the 1LE/z28 car, rated for more power and cheaper than the m10.
I was also looking at the mg9 from the zl1 camaro rated at even more power...which ironically is even cheaper new from gm, but after lots of research I have found some guys needing the change the input shaft to be shorter to work with the 6 bolt crank.
And rockland standard gear kinda raped me for the rear support bearing and clips at about 140usd shipped, but I figure it's a good mod to have before I throw the new tranny in. The zl1 type tranny has this bearing from the factory of course...but would require full disassembly to change input shaft and I don't want to do that.
I looked around at rebuilds and it seemed the most cost effective decision for me.
Audio_Rookie is offline   Reply With Quote
Old 07-27-2017, 10:53 AM   #7
bct10985
Drives: 2010 2SS LS3, 2013 duramax
I broke mine also. I was going to have rkt, rpm or tick performance do the rebuild with the billet output shaft but ended up putting a 4L80 in it. No one would sell me just the billet output shaft.
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 07-27-2017, 12:33 PM   #8
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10
The later TR6060's (past 2010) have been pretty robust. Don't waste your money on a "built" one, IMO, for the 2-cents it's worth.
In excess of 1,000WHP
LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
Old 07-27-2017, 02:38 PM   #9
enroberts
Thanks. Do you have a link to what you bought? Wondering if this will work (and I'd add the bearing support to it). Thanks!
Old 07-27-2017, 02:38 PM   #10
enroberts
What did this swap cost you?
Old 07-27-2017, 03:46 PM   #11
Synner
Drives: cars
Z/28 one will work and thats a killer deal but you'll need a tune due to different ratios, same goes for the 1LE or ZL1 trans since they all have the closer gearing ratios.
Old 07-27-2017, 03:52 PM   #12
enroberts
Thanks. So the input splines are the same from SS 6060 to Z/28? I want to be sure my upgraded Monster clutch and flywheel will work too. I can update the tune and I did for the new gears/rear I put in it. I'm assuming you're saying it will need a tune due to the speedo?
Old 07-27-2017, 09:02 PM   #13
Synner
Drives: cars
Yes speedo, flywheel should only need changing if you went LS7/LS9 due to crank bolt pattern differences but it never hurts to call and talk to Monster since I'm just an idiot on the internet with some scotch in me.
Old 07-28-2017, 12:33 AM   #14
Audio_Rookie
It should be a bolt in. I am up in Canada and this is who I used. They were the cheapest when I bought a zl1 fuel pump too.
https://www.gmpartswholesale.ca/oem-...ssion-24261736
I put it in my cart but didn't pay for the evening and was sent a discount code for 5% off too.
I also blew the main shaft and grenaded a bunch more. I want to track this car soon so we will see how it does. As far as tune, my guy is gonna tune me for more boost in a month anyway, he can change that....and account for the new 305 rubber :$
