Old 08-01-2019, 02:17 PM   #1
Wabbit
Wabbit's Avatar
Drives: 2013 2LT/RS SIM/Grey lnt/Sun/Nav
Footwell lighting
Finally looking at getting footwell lighting. I've seen a few, but the pictures seem off on how bright they really are. Also, the ones I've seen are all have switch for on/off I have to hit every time I want to see them.
I need something easy to install. Drilling holes all over the place is not preferred. I am not a super car gadget installer.
I would like it to turn on/off with the lights like the door panels.
I want it to be subtle enough that I can drive at night with them on and not interfere.
I don't want to break the bank.
It would be helpful if I can see the installation instructions before purchase.
I would not be offended if someone offered a reasonably priced local installer recommendation.
Rally Stripes - Check
Hockey Stripes - Check
Gills - Check
Ambient Lighting - Saving my $$$ now
Wabbit is offline   Reply With Quote
Old 08-01-2019, 11:24 PM   #2
silverstorm
silverstorm's Avatar
Drives: 2014 Camaro 2LS
I have footwell lights from Phastek Performance, $45 I think and they also came with dome light bulbs. Instructions weren't clear so I had to pay to get them installed, but I can send you pictures of how it looks and how it's wired. Mine are used with the switch without any holes drilled, but I know you can wire them other ways
silverstorm is offline   Reply With Quote
Old 08-10-2019, 02:53 PM   #3
Blackheart5815
Drives: 2014 Camaro convertible RS V6
I put red LED strips from Autozone in my foot wells. Pulled up the wiring diagram and tapped into the dome light so they replicate everything the dome light does. As the DL fades they fade. I’ll post pics tonight when it is dark and Monday pull up the schematics on which wire is the dL to tap into.
Blackheart5815 is offline   Reply With Quote
Old 08-11-2019, 12:38 PM   #4
hazy
Drives: 2011 2SS/RS
THIS is a great kit. Well put together, and insanely affordable at 45 bucks
4 strips of LEDs, fuse taps, all the wiring you'll need, RGB so you can select whatever color you want.
install is one of the most painless I've ever dealt with. Fuse tap to the Acc fuse in the interior fuse panel, ground to the bolt there, as well. Then just fish wires around and plug in the LEDs. All operate on one remote w one controller box.
Ran the wires for the rear seat out the fuse panel, down the drivers side trim, and up under the seat. Did the front/rear installs at separate times, just bc I didn't know if I'd like the look. All in, maybe 2 or 3 hours max, and that was taking my time, trying different things out and seeing what I preferred.
hazy is offline   Reply With Quote
Old 08-18-2019, 07:07 PM   #5
Wabbit
Wabbit's Avatar
Hazy - Looks interesting, I'll leave that one on the list.
What I really want is one that just comes on with the head/parking lights, just like the blue trim in the doors at night.
Gills - Check
Old 09-12-2019, 05:57 PM   #6
Tarendor
Tarendor's Avatar
Drives: 2012 camaro 2ss rs L99
I wired mine to come on the same as the door abl lights.
2012 2SS/RS, L99, no cats/mufflers, Holley Sniper low pro intake, Holley Sniper fuel rails, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. Snow methanol setup. custom 3gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, vitesse throttle controller, Innovate SCG-1, Hurst shifter with tap shift mod
Tarendor is offline   Reply With Quote
Old 09-14-2019, 09:42 AM   #7
sjmautoprod
sjmautoprod's Avatar
Drives: '16 2SS
See footwell portion here...
https://www.camaro5.com/forums/showthread.php?t=146279
sjmautoprod is offline   Reply With Quote
Old 10-08-2019, 09:50 AM   #8
myold88
myold88's Avatar
Just tap into the gray wire above the gas pedal. Footwells come on when doors are opened.
I didn't believe GM didn't make this standard especially on the 2SS/RS models. It's one of
the first mods I did 10 years ago.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
