Old 08-30-2019, 03:10 AM   #1
Ashen L99
Ashen L99's Avatar
Drives: Ashen grey, 1SS, L99
sold
Sold
K&N CAI, GPI ported throttle body, Power Wedge, Speed engineering long tubes, NPP Cat-back with X-pipe, Yank 3400 converter, 3.91s, mishimoto 169 Thermostat, Taylor plug wires, GM ground effects, Z/28 Spoiler, ZL1 10 spoke wheels.
Ashen L99 is offline   Reply With Quote
Old 08-31-2019, 09:03 AM   #2
tylerng1999
tylerng1999's Avatar
Drives: 2012 Camaro 1LS
Take $30 for it?
2012 Black 1LS M6: Cold Air Inductions Intake w/ Scoop, McNally Dual Valve Catch Can, 2.5 Inch Exhaust, Magnaflow Resonated X-Pipe, Muffler/Resonator Delete, SS Tips, 2017 ZL1 Style Rims, 255/45r20 Front, 275/40r20 Rear, SS Bumper Conversion w/ Fog Lights and LED "Knight Rider" Scanner.
tylerng1999 is offline   Reply With Quote
Old 08-31-2019, 01:34 PM   #3
Ashen L99
Ashen L99's Avatar
Originally Posted by tylerng1999 View Post
Take $30 for it?
Id take 40.
Old 08-31-2019, 04:28 PM   #4
tylerng1999
Old 09-07-2019, 06:01 AM   #5
Ashen L99
Ashen L99's Avatar
Bump
Old 09-09-2019, 09:50 PM   #6
Blown1LE
Blown1LE's Avatar
Drives: 2015 Supercharged Camaro 1LE
Just installed that stat last week
Made a huge difference on my car. Used to cruise at 203-207 and now cruises at 180 even in the Florida heat. The highest I have seen in traffic so far is 190 and my car is supercharged and carries a lot of under hood heat
Magnuson Supercharged 2015 1LE RS/2SS. Texas Speed Stage 3 Blower Cam. DSX Aux Pump. e85 Flex Fuel Kit. BMR Suspension. On Instagram @wakeyourneighbors @Blown1LE
Blown1LE is offline   Reply With Quote
Old 09-10-2019, 02:00 PM   #7
havelegs
havelegs's Avatar
Drives: 2015 1SS RS L99
Semi-related question, but would you need a retune if you installed this thermo?
havelegs is offline   Reply With Quote
Old 09-10-2019, 10:36 PM   #8
Blown1LE
Blown1LE's Avatar
I cant accurately answer that question as my car is tuned and my tuner adjusted my fan controls and told me to change the stat but years ago I changed my stat on my C5 Corvette without a tune and it was fine but that car was quite a bit older
I recommend this stat though if you are thinking about changing it out and its a very easy install
Old 09-11-2019, 04:05 AM   #9
Ashen L99
Ashen L99's Avatar
No I didnt change the tune, when I installed mine. Its basically drop in.
Old 09-12-2019, 10:11 AM   #10
havelegs
havelegs's Avatar
Thanks. I do want to get a lower tstat but my car has been tuned and the fans do come on early and full speed early. My temps aren't bad, in traffic they could get up to 205 in standstill traffic, moving down the road it is about 196-200 in 100+ degree ambient temps.
Anyway, I'll look into it next year since hopefully we will get cooler weather here in CenTX, one day..
Old 09-12-2019, 11:11 AM   #11
Blown1LE
Blown1LE's Avatar
[QUOTE=havelegs;10618653]Thanks. I do want to get a lower tstat but my car has been tuned and the fans do come on early and full speed early. My temps aren't bad, in traffic they could get up to 205 in standstill traffic, moving down the road it is about 196-200 in 100+ degree ambient temps.
Anyway, I'll look into it next year since hopefully we will get cooler weather here in CenTX, one day..[/QU
You are all set then this stat will do the trick. My temps have dropped 20 degrees with this stat and this one in a good deal
Old 09-13-2019, 02:49 AM   #12
Ashen L99
Ashen L99's Avatar
This thermostat drops the coolant to 178-188 while moving(obviously ambient air temps play a good part) and never above 195 while sitting. My low speed fans come on at 196 and they have kicked on only a couple of times on 95+ days.
Old 10-15-2019, 08:31 AM   #13
Ashen L99
Ashen L99's Avatar
Bump.
Old 10-17-2019, 03:40 PM   #14
CARABAS88
CARABAS88's Avatar
Drives: 2011 Camaro 2SS
I’ll take it. Do you take PayPal?
CARABAS88 is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
