Old 10-08-2019, 10:23 PM   #1
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
3 way NPP control
This was discussed on a thread somewhere here and I decided I would give it a try. I did it a little more complicated than needed, but it's as easy as 3 wires and an ON-OFF-ON switch if that's all you want. Enjoy
FasNuf is offline   Reply With Quote
Old 10-09-2019, 11:52 AM   #2
z28lt1
Drives: 2014 ZL1
Well done and excellent video. Thanks!
z28lt1 is offline   Reply With Quote
Old 10-09-2019, 10:17 PM   #3
FasNuf
FasNuf's Avatar
thank you , appreciate the feedback
Old 10-16-2019, 09:38 PM   #4
LD18SS
LD18SS's Avatar
Drives: 2013 Camaro ZL1
Nicely done!
LD18SS is offline   Reply With Quote
Old 10-20-2019, 12:16 PM   #5
FasNuf
FasNuf's Avatar
Originally Posted by LD18SS View Post
Nicely done!
Thanks Larry
Old 10-23-2019, 08:54 AM   #6
Katech_Zach
Katech_Zach's Avatar
Drives: 14 Camaro SS 1LE
Nicely done. I used the same method when I did mine ages ago. I put my switch where the sunroof switch would normally go since I do not have a sunroof.
This method is better than the standard "mild 2 wild" because there is no battery drain when the car is off. Stealth mode comes in handy when trying to be tame as well.
Katech_Zach is offline   Reply With Quote
Old 10-27-2019, 02:17 PM   #7
leemozoid
leemozoid's Avatar
Drives: '15 Silverado LTZ & '13 ZL1 ragtop
I have an extra Mild to Wild I'll let go cheap if anyone wants to go that way.
leemozoid is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
