04-26-2020, 07:04 AM | #1 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
Coilovers
So i lowered my car 1.4" front 1.5" rear with the springs from phastek rst x5 or something. The car looks great and it handles well but as i feared the struts are too low in the travel for around here. We have kinda crummy roads and a large dip will bottom me out. Rather than try another set of springs, pay for alignment then not like those as well i'm considering coil overs. I am not a road course racer and i don't push the limits in corners 95% of the time. I don't mind it being a little stiff but i don't want to bottom out i don't like hitting my head on the roof on the rebound.
I'm looking at all of these cheaper options on coilovers and wonder if anyone has tried them. I'm always for saving a buck but not if they are junk. Here's some i have found with a quick search. https://shop.redline360.com/products...SABEgJPJPD_BwE https://coiloverdepot.com/products/1...yABEgLZ0_D_BwE https://shop.redline360.com/products...SABEgKzEPD_BwE https://shop.redline360.com/products...CABEgJHE_D_BwE https://www.autoanything.com/suspens...CABEgKcq_D_BwE https://coiloverdepot.com/products/1...iABEgKOnvD_BwE All i want is to be able to set my ride height and have a ride that doesn't bottom out and drives a little better than what it is at now. I also noticed my car darts and follows the three crown of the road pretty bad. On the highway yesterday there was a pretty uneven crown from the left lane to the right lane and when i switched lanes the car was pulled all kinds of weird. I do have 275s up front and 315s in the rear road course tires so they are wide and grippy. I did retime the rear bushings tho i didn't do the fronts. I'm wondering if one of those bumps knocked me out of alignment when i bottomed out. I liked the stock ride comfort level i just hate the wheel gap.
04-26-2020, 09:17 AM | #2 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
My BC Racing Type BR have been on the car for 7 years. I have adjusted ride height and damp to suit current needs and conditions. No issues, yet.
04-26-2020, 09:19 AM | #3 |
Thanks for your input. Wondering if anyone has tried the rev9 or megan racing ones. They all seem to use the same spring rate and are adjustable.
04-26-2020, 09:54 AM | #4 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
Have you checked out Ridetech? That offer a good coilover setup. Also, what are your alignment specs? That will cause stability issues, such as the tracking problem you described. We are running the same size tires, and I have no tracking issues.
More to come. |
04-26-2020, 09:56 AM | #5 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
I like my Ridetech HQ’s. Easy single adjustable size. Best ride, no bounce, can order with spring rates you want(go to JDP). Million mile warranty. Handle great or set soft for best ride of any coilover. They aren’t cheap Chinese coilovers, but you get what you pay for. I had Pedders supercar coilovers before they went cheap and these are better. Megan’s are a cheap version of bc racing and not great from what I hear. I have never heard of redline brand. Pedders XA is like bc racing. But made cheap now as made in China. Years ago made in Australia and Taiwan and were good. Ridetechs are made here, and made for the Camaro as to valving,the others are not
04-26-2020, 10:07 AM | #6 |
The front was set to factory. I think -.09 camber each side. The rear .10 toe in and -0.05 camber i can grab the sheet. I almost think i knocked out out with one nasty hole i hit i don't remember it darting so much when i first had the alignment done.
04-26-2020, 10:11 AM | #7 | |
04-26-2020, 10:28 AM | #8 | |
SomeguyK
I wouldn't cheap out on anything. 2k for coilovers is actually cheap, considering other options. I paid roughly $1500 for my Ridtechs about 4yrs ago. Got them on during a sale. You wont be happy with cheap ones as the rebound, compression, and spring rates may not be matched well or even adjustable. Ridetech sent me new front springs for FREE due to an issue that wasn't theirs. They're plenty of options out there though.
More to come. |
04-26-2020, 11:25 AM | #9 | |
Best to do a search here, plenty of feedback on Pedders and bc racing. These were out first years ago and best there was at the time. Now made cheaper and maybe good for street only, was told that by people in the business,just no data on these as it has been years people here have bought them. But for your needs they maybe fine. As to the other brands do a search, I have researched on this forum at length, but have never heard or seen those other brands. Good luck! |
04-26-2020, 12:24 PM | #10 | |
I did use that chart as a guide for the rear. I left it factory for the front but if i swap maybe i'll go a little more negative on front camber. I already had to buy rear camber kit as they couldn't get it close with the stock ones. I think one of my bmr trailing arms was actually a little too long on my right side because it was all i could do to get it to bolt up with the eccentric bolts as loose as i could and of course that side was way the hell out of whack when they put it on the rack. But whatever they got it to what i asked for after buying the bolt kits at $80 per set.
04-26-2020, 01:18 PM | #11 | |
SomeguyK
More to come. |
04-26-2020, 02:04 PM | #12 |
I don't know it was one from GM that's why it was so much. The dealer supplied it as it was there when we discovered we needed it. All of the spring rates for the cheaper coilovers is 8kg front 12kg rear. The adjuatment is a single knob soft-hard doesn't have individual compression or rebound settings. I've done some research online. Godspeeds don't seem to get good reviews stiff and leaking at 15k miles. Megan racing is mixed but mostly negative for being stiff. Rev9 seems fairly new and could only find reviews from honda owners that say they are good, not too stiff just don't go as low as megan racing but i'm not trying to slam the thing like they are. Rev9 i think was cheapest $500. Bc and pedders are about $1k but behind above i guess they are made more cheaply now, so i wonder if it's the same quality as the real cheap stuff. It seems pretty uncharted waters for camaros so i might just be a Guinea pig. They do all carry a 1 year warranty. Suppose I'd just keep my shocks and struts for a while in case i need to swap them back. If i do then i could just go with the 1" lowering springs.
04-26-2020, 02:35 PM | #13 |
I run Megan’s on my V6. Ive had them on for 3-4 yrs now. When I did research back then, anything under $3k where all the same. I enjoy mine and I got coilovers to get a stance the lower springs couldn’t give me. I spent some time getting the stance and adjustments just to my liking. It’s softer than my Z28 but I could dial it to a bit stiffer if needed. The coilovers are only a part of my suspension that does quit well.
Good luck |
04-26-2020, 03:14 PM | #14 | |
To compare, Ridetechs come with 275/500 springs for best ride and control. I went with 300/550 rates as I autocross. Ride is still good and controlled, not stiff and no bouncy. |
