05-16-2018, 07:31 PM | #1 |
Drives: 2015 Camaro 1LE Join Date: Sep 2015
GPI 416 Stroker Max Package Build / Results Are In !!!
As some may know, my car was the 1st car to get the LS3 Max Package from GPI and the car performed great and made awesome power. Well the clutch started giving me issues right away. So back down to GPI for a new clutch, and of course you can't stop there.
Now, its getting a forged bottom end and stroked to a 416. Callies crank and rods and Wiseco pistons. We decided to bump the compression to about 12.5, Manley timing set, Melling oil pump, port match the MSD Atomic intake, and install new CenterForce Dyad clutch and MGW short throw shifter. Car made 542 rwhp and 463 tq. last time, I'm putting the over/under at 585 rwhp and 540 tq. What's everyone's thoughts on reaching these numbers? I have attached a few pics they sent me of the build progression. Last edited by Arch-City; 05-30-2018 at 07:01 PM. Reason: Add Results |
05-16-2018, 08:11 PM | #2 |
'It's an experiment'
Niiiiiiiiice!
GPI does awesome work, they did my stroker too... -Don
747 RWHP 794 RWTQ
05-16-2018, 08:18 PM | #3 |
Looking forward to seeing the results of this!
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, RPM 5” CAI, Kooks Headers, Solo Cat Back, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP Last edited by Ashen 6.2; 05-17-2018 at 05:16 AM. |
05-16-2018, 08:55 PM | #4 |
Drives: 2015 1LE Join Date: Oct 2015
Bad Ass! I have to say, you dont mess around.
05-16-2018, 10:33 PM | #5 |
Drives: 14 SS/ 1LE Join Date: Jun 2013
nooice
2014 1SS/1LE
AGP 57/57s, E85 + meth injection, Monster triple, ZL1 diff swap, Z28 coilovers |
05-16-2018, 10:49 PM | #6 |
Drives: 2010 Camaro 2SS Victory Red 6M Join Date: Apr 2015
I don't think you will be 540tq, maybe 490 to 510. That's still a healthy number by a long shot! Hell, your pre build numbers were pretty stout. Post the dyno sheet of before/after so we can see the curves!
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19 Gone on 12/28/19 R I P 2010 2SS 6M Victory Red/Black (old ride) CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back. 12.6 @ 115 SAR as of 9/19/15 Gone but never forgotten. |
05-17-2018, 06:12 AM | #7 | |
He was running .6 more compression and a touch less intake duration and made 685 and 650 flywheel power numbers, so I thought I may have a shot. I may be leaving some power on the table until I upgrade the to 3" exhaust and a 102 or 105 throttle body, ( I will be adding the exhaust and axles later this year.) As far as dyno sheets go, I will not have a before other than my current one that shows the 542 / 463. But, I will have 1 for the new build on the same Dyno just on a different day. Either way, it is going the be one bad bitch, especially in the mid-range with the torque boost and the MSD intake. |
05-17-2018, 06:28 AM | #8 |
Drives: 2014 2SS/RS Join Date: Feb 2015
OP, do you track the car? If so do you mind sharing 1/8, 1/4 ETs from old setup? I'm planning out my next steps and would love to see some track results.
2014 2SS/RS TH400 Swap, CAI Cold Air Intake, SW LT's, PTB, GPI Intake Mod, Circle D Converter, DSS 9in conversion and Gears, GPI Cam and Heads..Tuned by "Ryan" GPI
05-17-2018, 06:48 AM | #9 | |
Right now, I am just having fun with a weekend toy, and laughing at Hemi and Coyote owners scratch their heads and constantly ask about the set-up. |
05-17-2018, 07:22 AM | #10 |
Glad to see centerforce lightning the clutch up some. What does this set up weigh? Nice set up.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85 Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE 10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake Best 1/8 6.80@105.75 Best MPH 134.82 |
05-17-2018, 08:02 AM | #11 |
I don't know for sure the weight savings, only info I have found is that it is close to OEM weight. I have sent a email to Centerforce to try and get this info. I will keep you posted when I hear back from them.
05-17-2018, 10:55 AM | #12 |
Drives: 2010 Camaro (M6) 1000+ HP SBE Join Date: Jun 2011
[QUOTE=Arch-City;10187604] Car made 542 rwhp and 463 tq. last time, I'm putting the over/under at 585 rwhp and 540 tq. What's everyone's thoughts on reaching these numbers? QUOTE]
Dude, Very Nice! I think your expectation will be very close to actual. I always heard ~ 2 hp gain per cui and the stroke change will send the torque to the roof. Let us know how it goes!
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam Brodix BP BR 3 Heads Kooks LT Headers and full 3" exhaust Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears McLeod RXT Twin HD Clutch & Upgraded Slave RPM Level VII TR6060 BMR Drag Suspension Package w/Strange shocks Carlyle 15" and M/T ET Street R radials 10.1 @ 143 mph 1/4 mile |
05-17-2018, 09:36 PM | #13 | |
The Dyad clutch is supposed to have really good ( close to stock ) street manners, but with a hell of a lot more holding capacity. It is rated up to 1300 LB/FT. |
05-18-2018, 09:05 AM | #14 |
Just don't ever try to launch it via slipping heavily. I've read numerous stories about people slipping it and it getting toasted in short order.
Thread Tools | |
