Old 06-04-2020, 02:15 PM   #1
g1o1101
g1o1101's Avatar
Drives: 2011 Camaro 2SS L99
Exclamation Code p0443
Got DTC p0443 malfunction in purge valve or control circuit. I’ve replaced the purge valve and that didn’t solve the problem I’m guessing it’s a wiring issue. Can anyone point me in the right direction thank you.
g1o1101 is offline   Reply With Quote
Old 06-04-2020, 11:34 PM   #2
'10CamaroDude
Drives: 2010 Camaro LS
Then all you got is circuit (plug, wire), or the control circuit in the ECU.
'10CamaroDude is offline   Reply With Quote
Old 06-06-2020, 09:42 AM   #3
g1o1101
g1o1101's Avatar
Checked fuse 32 for the purge valve and it looks fine gonna test the connector next
Old 06-26-2020, 11:22 AM   #4
g1o1101
g1o1101's Avatar
So I think the connector was bad however I went ahead and just got rid of it. Put a filter on the hardline and capped off the intake. Also got the codes turned turned off so no CEL. Haven’t had any issues
Old 06-26-2020, 01:19 PM   #5
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
Next time posting your question in the proper sub-forum will usually get you an answer quicker. This is the Member Car Journals section. Just a heads up. Good luck
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
