04-15-2012, 09:13 PM | #1 |
Drives: 2012 ZL1 #36 Join Date: Feb 2012
Minor issues
Took delivery yesterday. Absolutely love the car and haven't even broken it in yet. Was a little anxious as I have driven vettes for over 20 years including a Zo6 I just sold to make room for car 36.
Have noticed a few minor issues and wanted to see what you guys think. First I am hearing a ruffling sound-like paper flapping when driving over 50. It's coming from the driver side rear of the driver. My husband and son hear it too and none of us can figure out what it may be. Nothing visible is loose on the car or under it. ANY IDEAS??? Next the speaker cover on the door has a metal nameplate glued to the cover and it appears to have discoloration on it. Any ideas? Finally I am thinking of adding stripes behind the doors on the ridges...... Has anyone added stripes or modified their cars yet and if so....what...... And yes I will let the dealer know this week when I get a chance.....but...you guys have been very knowledgable through this process and I thought I would try you all first. |
04-15-2012, 09:16 PM | #2 |
Drives: 2013 ZL1 Join Date: Sep 2011
That ruffling paper sound would likely be a Shelby trying to pass you........
04-15-2012, 09:34 PM | #3 |
Formerly Camaroc5
Drives: 2010 Camaro LT/RS M6 Join Date: May 2010
Heat shield? I have a heat shield lose and the sound comes from the shifter area. Thing flaps in the wind! Driving me crazy
Sent from my DROID RAZR using Tapatalk 2 |
04-15-2012, 09:44 PM | #4 |
Drives: Mitsu EVO / 3 series Join Date: Feb 2009
04-15-2012, 10:01 PM | #5 |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
This has come up in the past, with a little paper tag on the drive shaft.
04-15-2012, 10:01 PM | #6 |
Order in on 13' ZL1 vert
Quick question.....have you had enough seat time in her to know how it compares with your former Z06?
04-15-2012, 10:48 PM | #7 |
Drives: SuperCharged 2SS/RS IOM MN6 Join Date: May 2009
Look underneath and in the engine bay, there maybe a loose part label
flapping around. |
04-16-2012, 07:16 AM | #8 |
Fast Orange
First I am hearing a ruffling sound-like paper flapping when driving over 50. It's coming from the driver side rear of the driver. My husband and son hear it too and none of us can figure out what it may be. Nothing visible is loose on the car or under it. ANY IDEAS???] Try checking the side skirt. I had the same noise and over the weekend found a couple of the connections were loose or had been popped out, probably in the loading/unloading from the train or truck. This morning that seemed to fix it. Good Luck. |
04-16-2012, 07:36 AM | #9 |
aka Patrick
So far all great Ideas to check.
I had some of the same issue and it was a tag causing it. I pulled tags off the springs, Drive Shaft, rear difusser....etc...
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft |
04-16-2012, 07:42 AM | #10 |
Deep Sea
Drives: 2012 Camaro ZL1 Join Date: Sep 2011
Seat belt pops loose out of the magnetic seat belt holder thingy.
Sit at idle and turn on and off your high beams and tell me if you get an unusual noise. Unusual gas consumption, drove the car for 4 days and the tank was empty, could there be a leak,,,,,,,,? |
04-16-2012, 08:15 AM | #11 |
Rebirth of muscle
Drives: 2012 ZL1, 2004 Denali, 2001 Jetta Join Date: Feb 2012
Yea, it's leaking out the exhaust. High fuel consumption due to break-in.
GBE, B92, MN6, CF5
VIN: 2G1FS1EP3C9800455 |
04-16-2012, 08:18 AM | #12 |
Deep Sea
04-16-2012, 08:41 AM | #13 | |
Four days is rather good out of a tank of gasin a new car. When I get my SS I did than in a weekend.
04-16-2012, 09:06 AM | #14 |
Petro-sexual
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // RFBG // Soler 103 // TooHighPSI Port Injection // THPSI Billet Lid // FF // Katech Drop-In // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
