02-02-2018, 06:30 AM | #1 |
Drives: 2016 2SS Join Date: Jul 2016
H/C cars making peak power around 6,700?
I am looking for dyno graphs of H/C cars pulling to 7K and making peak power around 6,700 or above. I am trying to run down an issue. But most of the graphs I have seen have peak power around 6,300-6,500 and then falling off or hitting a dip and going flat. I would really like to see one of these 7,500rpm screamers I hear people talking about.
2016 2SS. H/C SBE 1.37 60ft, 6.36@109.49, 9.97@136+. Nuff Said.
02-02-2018, 10:16 AM | #2 |
Drives: 2013 SS Join Date: May 2013
It would also depend on the cam I am planning on spinning mine to 7500rpms on a pretty aggressive cam
02-02-2018, 01:20 PM | #3 |
Drives: 2017 2ss, m6 Join Date: Jan 2017
Well you really don't have the capability with the GM cylinder head casting to get the airflow needed to spin the engine all that high. Sure, you can cam it to the moon and get it there but you won't see it building good power. If you can't get a head into the 360 c.f. range you won't like the power curve of a NA unit above 7250. Jmho
02-02-2018, 01:30 PM | #4 | |
02-02-2018, 01:33 PM | #5 |
The cams are decently aggressive I guess. Mid to high 220's/230's 111 lobe sep. 7* and 11* of over lap. In LS3's they pull to 7K.
02-02-2018, 01:40 PM | #6 |
These are two different cams in 5th gear. The top is my STG 2 on a healthy motor. The bottom is the STG three cam but my motor is not healthy. It will be soon though.
02-02-2018, 01:52 PM | #7 |
Drives: SS 6 speed of course Join Date: Jan 2016
https://ls1tech.com/forums/generatio...yno-graph.html
http://www.hotrod.com/articles/how-t...-supercharger/
Forged short block, large duration sub .600 lift Cam Motion cam, 7200 RPM fuel cut, Pray Ported Heads, 3.85 pulley D1X, stage II intercooler, DSX secondary low side, DSX E85 sensor, Lingenfelter big bore 2.0 pump, ported front cats, 60608 Borla, LT4 injectors, ZL1 1LE driveshaft and Katech ported TB, ported MSD intake, BTR valvetrain, ARP studs, ProFlow valves, PS4 tires.
02-02-2018, 01:59 PM | #8 |
Looking for some real world results at the wheels.
02-02-2018, 02:01 PM | #9 |
This is a pretty small cam with ported Stock top end. It flattens out up top but doesn't fall off.
02-02-2018, 05:51 PM | #10 |
Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
The max power on my little cam is 536 @ 6115. It does drop off around 6400.
________________________________________________
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ |
02-02-2018, 09:45 PM | #11 | |
Drives: 2016 Camaro 2SS Join Date: Mar 2016
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
02-03-2018, 05:44 AM | #12 |
Drives: 2017 Camaro 1SS Join Date: Aug 2016
02-03-2018, 08:00 AM | #13 |
SABIO
Drives: 2016 CAMARO 1SS Join Date: Jul 2015
Wish I could say mine did. I peak at 6K and it hangs there to about 6,700.
I could probably use a better Cam. Missing out on 50hp
02-03-2018, 01:35 PM | #14 |
I am going to give it one more shot with a different cam in my car.
