Old 05-25-2018, 12:24 AM   #1
Starfall
1bad6
Starfall's Avatar
Drives: 2010 camaro
V6 shooting flames / popping general questions
I'm extremely curious about a video i recently seen on a v6 camaro shooting flames and popping, i really don't know much about any of this stuff. So first i'm going to start with the video
https://youtu.be/SFPzvP1qcKk
#1
Now to the questions, i have a mrt v1 axleback, stock cats and i still have resonaters, how can i get my car to pop and shoot flames like this? if i remove the res's and do straights, would that work?
#2
How is he getting it to pop like that? Is he revving it up high and completely letting it off the gas or is he pressing his foot on the gas at around 3-4k to make it pop? My car pops alot at around 3-4k but i have to feather the throttle almost, and the pops aren't very loud
#3
Is this happening because he has no cats/res's? Or is it because of the tune, if so what tuning companies offer this, i don't believe trifecta does. Thank you
Mods: trifecta tune on 93 pump gas, mrt v1 Axle-Back, drilled/slotted rotors, 4" quad tips, Res delete, big worm gfx black out kit all around, interior footwell lights.
Starfall is offline   Reply With Quote
Old 05-25-2018, 05:27 PM   #2
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
It's all tuning. (and having high flow or no cats) High horsepower cars spit flames because of the air and fuel being moved (and by extension usually the extreme AFR difference when not under load, so all the excess fuel detonates in the exhaust). This is just tuning. Anyone can do it, it's not technical or anything, no benefits to it, it's just "cool".
But you also have to realize that this occurs every time you let off the throttle, and depending on how aggressive the effect is, it can continue for some time. I'd imagine it would get obnoxious after a while. A couple guys at Eurocharged near me said they did an SS with a flame tune but he wanted it taken off because it was so obnoxious.
If you were catless you could put spark plugs in your exhaust and turn them on when revving... same effect. That's, ahem, something my late grandfather told me they did back with their carb'd engines.
DSX_Camaro is offline   Reply With Quote
Old 05-30-2018, 05:23 AM   #3
Starfall
1bad6
Starfall's Avatar
Drives: 2010 camaro
I'm not looking for something crazy, i just want some loud bangs / pops with a little bit of flame when letting off from WOT, do you know any tunes that can do this?
Old 05-30-2018, 08:58 AM   #4
DSX_Camaro
DSX_Camaro's Avatar
You'd have to ask the tuners up front.
Old 05-30-2018, 09:16 AM   #5
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
Negative timing in the low load, mid-RPM range will cause it along with slowing up the DFCO (Deceleration Fuel Cut Off) settings. My Camaro V6 will spit flames during shifts, and it isn't by design, just from the HP I was running. I had my Mustang 5.0 tuned to making popping noises during deceleration, until it did it when I passed by a cop who was outside his car and he gave me the look of death. Turned it off after that.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
