05-25-2018, 02:45 PM | #1 |
Battery
What is everyone replacing their battery with? Looking for part numbers.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/ |
05-25-2018, 03:51 PM | #2 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
Ac Delco. Call your local dealership.
More to come. |
05-25-2018, 03:55 PM | #3 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
ACDelco 94RAGM
But it's looking out of stock in a lot of places...
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
05-25-2018, 05:24 PM | #4 |
No upgraded aftermarkets worth a shit?
05-25-2018, 06:25 PM | #5 |
Why? If you drive a modified 2010, and your stock battery is still doing well and only replacing it after 8 years, why change it up?
05-25-2018, 07:22 PM | #6 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Let Google be your guide. Dealership, parts store, online. I may be the odd man out, but a battery is a battery.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
05-25-2018, 08:00 PM | #7 | |
I'd like something with some more ass behind it if possible.
05-26-2018, 11:46 AM | #8 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Optima has a new OEM style replacement, released at SEMA this year. Looks more OEM style than their red/yellow/blue top. Might be worth a try, but I don't know the price point.
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
05-26-2018, 11:59 AM | #9 |
Drives: 2011 Camaro 2SS Join Date: May 2016
just get oem or find a higher CCA, battery is a battery
2010 Camaro 2SS-Mods: Nightfury cam, CNC ported LS3 heads, CNC ported TB, Ported Intake, RX Catch Can, MGW Short Throw Shifter, Mantic 9000 Clutch, TSP 1 7/8 headers, catless NPP, BMR trailing arms, MMR Z/28 Reps 20" gloss black. SOLD
2011 Red Jewel Tintcoat 2SS-Mods: Edlebrock E Force S/C w/ 3" pulley swap,Texas Speed roller Boost Cam 227/235, 641"/649", 114 LSA, PRC Ported Heads, Ported TB,ARH 1 7/8 headers, McLeod RST twin disk 1000 hp clutch, ZL1 Fuel Pump, 620whp |
05-26-2018, 02:22 PM | #10 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Went with a Interstate Megatron ,perfect fit has the vent just like the OEM.
OLD GUY FLYING FAST AND LOW
05-28-2018, 12:30 AM | #11 |
Drives: 2010 Join Date: Mar 2015
I replaced mine with OEM AC Delco, and have no complaints.
05-28-2018, 10:26 AM | #12 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Get a battery for a C6 Corvette it's 10 pounds lighter than the stock one and still has good starting power when temps hit single digits
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
05-28-2018, 11:15 PM | #13 |
Drives: 13' 1LE Join Date: Apr 2012
Get a lightweight batt, if the weather permits. I had a braille 14lbs and it never skipped a beat, even with 0F weather.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
