Old 06-23-2014, 11:22 AM   #1
angie7
Smoked by a GIRL
angie7's Avatar
Drives: 2014 2SS/RS
set up Q's to run 315s
My stock tires are getting thin at 19k miles so I'm looking to upgrade my rims and tires. I'm wanting 315s on the back but curious if I'll need any type of spacers. I'd also like to lower the car an inch, any rubbing? I know I'll need 20x11 rear rims, how much weight does this add? Not worried about gas mileage as it isn't a daily but does it effect it t all? Any issues with this set up I need to be aware of?
Thanks!!!!
2014 2SS/RS Summit White w/ IOM interior "Powder 2.0"
angie7 is offline   Reply With Quote
Old 06-24-2014, 05:10 AM   #2
Denis
Denis's Avatar
Drives: 2010 SS
i used to run 20x11 TSW Nurbergring's and there was no spacer needed. as far as lowering/rubbing thats all going to depend of the offsets you get. the right wheels with the right offsets will be just fine. my 20x11 nurbs with 315's never rubbed once and im lowered 1.25" on Pfadt springs. and as far as weight, again it depends on the wheel you choose. the TSW's were lighter than stock and wider.
hope that helps
Old 06-24-2014, 01:31 PM   #3
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
I have 20x10.5 with nitto motivo 315s in the rear. I'm also lowered an inch in the rear and have no rubbing issues whatsoever. I have some pics in my build thread if you're interested
Old 06-24-2014, 06:12 PM   #4
EmeryZ28
EmeryZ28's Avatar
Drives: 2011 Camaro 2SS/RS LS3
I have 20x10.5's out back +35 offset. 1" BMR drop and my 315's do not rub, I've taken hard corners, and hit some dips in the highway at 80MPH, also launched hard and banged 2nd gear. no rubbing whatesoever.
2015 Silverado Z71 6.2/2011 Camaro 2SSRS LS3/2014 Cadillac ATS 2.0T
EmeryZ28 is offline   Reply With Quote
Old 06-25-2014, 12:16 AM   #5
angie7
Smoked by a GIRL
angie7's Avatar
Drives: 2014 2SS/RS
Awesome, thanks for all the info! This has helped a lot. I'm looking at Forgestar F14s wrapped in Vreds. 20x11 rear and 20x9 in the front.
Old 06-25-2014, 12:17 AM   #6
angie7
Smoked by a GIRL
angie7's Avatar
Drives: 2014 2SS/RS
Yes I would be interested, do you have a quick link? Thank you
Old 06-25-2014, 09:28 AM   #7
lscamaro
lscamaro's Avatar
You can click on my Sig pic and it'll take you there. The pics should be on the last page
Old 06-25-2014, 10:53 AM   #8
angie7
Smoked by a GIRL
angie7's Avatar
Drives: 2014 2SS/RS
The wheels look awesome!!!!!! Thanks for the info. I'm not pulling the trigger until over the winter when my Camaro is in storage so I have a while to look and make a decision.
Old 06-26-2014, 04:01 PM   #9
kcsr6
kcsr6's Avatar
Drives: 2011 Black LS3 2SS/RS
I have Forgestar f14's with nitto invo 315's with no issues.
2011 2SS/RS, Torch Red Bow Ties, 5% Tint, Oracle Side Markers, Forgestar F14's, Pfadt lowering springs, Vararam Intake, VMax Throttle Body, Custom Grind Comp Cam 224/236 114, SLP Under Drive Pulley, Granatelli Wires, Kooks 1 7/8 LTH, Off-road pipes, 3" exhaust, Mike Norris Motorsports Tune 471 RWHP 449 RWTQ! Search for kcsr6 on YouTube for sound clips.
kcsr6 is offline   Reply With Quote
Old 06-26-2014, 08:44 PM   #10
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
Don't forget to pull back the parking brake cables to clear the wider wheels. Do a search on the forums.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
