04-05-2017, 03:32 PM | #1 |
Drives: . Join Date: Jun 2016
Master Cylinder brace?
Noticed when I was bleeding the brakes this evening how rubbish the master cylinder mounting is (for a proper motorsport car). Presume it is a carried over part from the standard Gen 5 models.
When your assistant is sitting in the car pumping the pedal if you stand by the engine bay you can visibly see the bulkhead/master cylinder mountings flexing and the reservoir moving. Common problem on lots of cars and normally there is an aftermarket solution for it: GT86: 2017 WRX STI: 2015 WRX STI Mazda RX7 Anyone making anything good for the Gen5 Camaro? Will make something up myself if not... The brakes on the Z are already fantastic, and this mod won't improve stopping power but it will reduce pedal travel and improve pedal feel. |
04-05-2017, 04:14 PM | #2 |
Jumanji
Drives: '14 Z/28 - AGM - No A/C Join Date: Mar 2014
Worth it for the pedal feel alone. Interested in what you are able to fab up.
Keeper of the 5th Gen Z/28 Registry.
Registry Facebook. Follow: @5th_gen_z28_registry I track wrecked Z/28s Total lost -41 |
04-05-2017, 04:42 PM | #3 |
Drives: Z/28 Join Date: Oct 2015
I looked into making a brace when I first got my Z. There is no good place to mount it without drilling holes in the shock tower as it is completely solid on the back side facing the fire wall or some elaborate bracketry. I ended up not trying anything as it was not worth the effort in my opinion and I didn't want to drill any holes. I was also thinking about welding an integrated brace to the strut tower brace???
04-05-2017, 06:04 PM | #4 |
Drives: 2015 Z/28; 1969 Camaro SS Join Date: Nov 2015
Seems like a new item for Moreno MS or the ZL1Add-ons guys.
