Old 10-25-2019, 11:49 AM   #1
champwynn
Drives: 2012 Camaro 2SS 2002 Camaro SS
$4700 ON LABOR FOR LSA INSTALL??
VVT DOD DELETE WITH CAM INSTALL $1000 (10 HOURS)
HEADER INSTALL $400(4HR)
LSA INSTALL $1500 (15HRS)
ICE TRUNK TANK INSTALL $300 (3HRS)
ZL1 PUMP AND DSX AUX PUMP $600 (6HRS)
CYLINDER HEAD MACH SHOP $400 (4HRS)
TUNE $500
TOTAL 4700
Is this over priced? Since the LS3 intake and front accessories are coming off anyways. The mechanic would just be placing lsa parts in replace the ls3 parts?I understand it may take a little more work but 15hrs?
2002 Camaro SS mods (a lot)
2012 Camaro SS mods (a little)
champwynn is offline   Reply With Quote
Old 10-25-2019, 11:53 AM   #2
Vegas Bound
Drives: 2013 Sparkly Red One
Doesn't seem unreasonable. Might as well do flexfuel while you have everything apart.
Vegas Bound is offline   Reply With Quote
Old 10-25-2019, 12:13 PM   #3
champwynn
The dsx aux pump is for the flex fuel.
Old 10-25-2019, 12:21 PM   #4
Scott S
Scott S
Drives: 2011 Camaro 2SS
Labor
Unfortunately if you can not do it yourself you are going to pay...
769HP/699 Torque LS3 heads ported and polished with BTR Spring kit & Trunion upgrade, LSA supercharger ported by DC Porting, 102MM throttle Body, 2.40 pulley upper pulley, Innovators West 10% Overdrive lower, BTR Stage 3 PDS Blower Cam, Mighty Mouse Catch Can, SMG Flex Fuel kit, SMG Aux Fuel System, FIC 1000 Injectors, MGW Flat Stick Shifter, RPM Stage Vll Transmission, McLeod RXT clutch, ARH 1 7/8 Headers, 3" X-pipe with Borla S-Type mufflers, ZL1 3:23 rear diff and Axles, 1LE suspension. Bmr Bushings in back. TUNING AND SPECIAL ALIGNMENT BY CARL@Twincitiesperformance
Scott S is offline   Reply With Quote
Old 10-25-2019, 01:21 PM   #5
champwynn
I don't mind paying, I just don't want to pay more than I should have to.
Old 10-25-2019, 01:36 PM   #6
RankSS
Drives: 2010 Camaro SS
I think you are getting a lot done for the money. This is only true if they stick to this price and not try for more after.
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
RankSS is offline   Reply With Quote
Old 10-25-2019, 01:38 PM   #7
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
That sounds cheap for all that youre doing.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 10-25-2019, 02:20 PM   #8
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
TUNE $500
TOTAL 4700
Everything seems reasonable except the lsa install. I don't see how it could possibly take 15 hours to bolt on a supercharger and brackets
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 10-25-2019, 02:27 PM   #9
champwynn
That's how i feel. Everything looks great except the lsa install for 15 hours.
Old 10-25-2019, 03:16 PM   #10
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Agreed, 15hrs for the LSA install, in addition to the rest is excessive. Should be more like 5hrs (or less), IMO.
I could see 15 hours (still seems like a stretch) for just the LSA install by itself, if that was the only work being done. I've done the LT4 conversion on an LT1 Corvette, a bit more involved than the LSA conversion on the L99, and that didn't take more than 15 hours in total.
-Scott
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 10-25-2019, 03:37 PM   #11
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
Shop around and see
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 10-25-2019, 04:24 PM   #12
champwynn
Originally Posted by hunter1660 View Post
Shop around and see
I live in Socal, options are slim. very slim
Old 10-25-2019, 07:39 PM   #13
hammdo
'It's an experiment'
hammdo's Avatar
Yeah, LSA install price is high. They are already doing most of the work with the DOD. I did all of that (except I did meth tank) myself and the LSA kit install after all the rest is much less time. You’re also paying for a full tune so, normal install with tune for LSA kit is ~$1200-$1300.
Just my humble opinion...
-Don
747 RWHP 794 RWTQ
Old 10-28-2019, 04:03 PM   #14
champwynn
-Don
Thank you! I always respect your opinion!
