02-01-2019, 02:38 PM | #1 |
Drives: '23 LT1 A10 Join Date: Oct 2015
Reprogram after fluid change??
So I went to a shop to see what it would cost them to flush the trans fluid. He said he would not do that but drop the pan, replace filter and REPROGRAM it. I was shocked to hear this and asked why he would have to reprogram it. The car has been tuned so I am not going to let anyone reprogram the trans. His answer was that after the fluid is dropped the trans goes back into a learn mode, which he said could cause a lot of slipping if not reprogrammed. Is this bullshit or what!?!?
02-01-2019, 03:09 PM | #2 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
Go somewhere else.
02-01-2019, 03:35 PM | #3 |
Thread Tools | |
