06-09-2012, 02:56 PM | #1 |
ʇuɐıʌǝp lɐıɔos
Drives: 2011 2SS/RS LS3/M6 Join Date: Feb 2011
Cam Install Problem
I am in the process of installing a Comp 54-459-11 LSR cam 231/239 .617/.625 113 in a 2011 Camaro LS3. I have the cam installed at 109* ICL as the cam card says. I have verified this numerous times. I am using the checking springs/dial indicator method to check PTV clearance. I am getting about .041 for intake and .100 for exhaust. I have a couple questions about this situation.
I also installed a Cloyes Hex-a-just timing set and was wondering how much I would have to install the cam retarded to get more reasonable numbers like maybe .060 intake and .080 exhaust? How much would this affect the overall performance of this cam. The car has 3.91 gears so they should help with any shift up in the power band. Any advice on this situation would be greatly appreciated. Thanks. Last edited by toml_pa; 06-09-2012 at 03:13 PM. |
06-09-2012, 03:01 PM | #2 |
06-09-2012, 03:41 PM | #3 |
Drives: A wrench Join Date: Jan 2010
What kind of valve springs are you using? A good spring will let you get away with a lot less PTV than some others.
.040 is tight. That's one misshift away from a valve/piston kiss. You can retard it back to a 111ICL and should be fine. I've ran PTV as tight as ~.050-.060 before with no issues, but that's with a properly set up valvetrain and good springs. The general ".080" minimum isn't set in stone. Just depends on the set up. Or go with a smaller cam. Good luck |
06-09-2012, 05:09 PM | #4 | |
ʇuɐıʌǝp lɐıɔos
After retarding from 109* to 111.5*, I now have about .052 intake. Didn't check exhaust yet, but I assume it moved a similar amount in opposite direction. So what else might this affect other than moving the power band to a little higher RPM? |
06-09-2012, 05:49 PM | #5 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
Damian is correct, we never go with less than .080 clearance.
Also, you can't guess on the pushrod length. You may be close or get lucky.....but no matter what the cam grinder or vendor tells you about pushrod length, you really need to measure for proper pre-load after everything else is installed. There are to many variables to guess. |
