05-30-2013, 11:37 AM | #1 |
Drives: 2014 Blue Ray Met. Camaro 1SS Vert Join Date: Feb 2012
Amp installs
Post pictures of some of your amp installs. Where is the factory amp located? Pictures of amp racks and amp wire install pictures at the battery. Where are most of you installing the ground for the amp? Any help and pictures would be great!! Thanks
05-30-2013, 11:45 AM | #2 |
Drives: 2013 Blue Ray Blue 2LT Join Date: Sep 2009
AMP is in the trunk on the left rear behind the carpet.
05-30-2013, 01:05 PM | #3 |
Drives: 2ss/rs vr 6m Join Date: Mar 2009
I made my own amp board and put it in the factory location. Behind the carpet by driver side tail lights. Ran ground to the body.
05-30-2013, 01:09 PM | #4 |
Drives: 13' Sw 2ss Ls3 Join Date: Dec 2012
Install I did on a buddies camaro
05-30-2013, 01:14 PM | #5 |
This
05-30-2013, 01:19 PM | #6 |
The Barber is the amp staying attached to the rear seat? I heard there is nothing really to bolt to?
05-30-2013, 02:06 PM | #7 |
Small wood screws on all 4 corners and its pretty much set there not much movement and still holding up small amp so not much weight
05-30-2013, 02:14 PM | #8 |
Mine
05-30-2013, 02:19 PM | #9 |
1000 Watt soundstream
05-30-2013, 02:21 PM | #10 |
wonder if anyone's tried to stuff 15s or bigger(maybe 1 18" Stroker)..
^^Soundtream rocks(oldskool stuff, class A)^^ |
05-30-2013, 02:53 PM | #11 |
I think 2 12s upright is the most u can stuff in there may b 15s or 18 laying flat could b possible not sure on the sound quality u would get from a sub or subs in that position
05-30-2013, 03:05 PM | #12 |
Here is my 10" Kicker box I just put in today but trying to decide where to put my amp.
05-30-2013, 03:21 PM | #13 |
Back of the seat seems to be convenient enough for me kinda no where else to mount with out fabricating somethin up
05-30-2013, 04:21 PM | #14 |
Drives: Rally Yellow 2010 1Ls Join Date: Oct 2012
Amp location
Mines mounted on backside of subbox but i got dual 10s.
