01-19-2016, 01:31 PM | #1 |
Drives: 2013 SS 1LE Join Date: Nov 2011
BMR trailing arms
BMR trailing arms / Black New in box $85 shipped
01-19-2016, 04:17 PM | #2 |
TCA026 is model # Good for 2010-2015 Camaro and other applications
01-19-2016, 04:37 PM | #3 |
Drives: 2010 SS RS Join Date: Jan 2015
Do these fit stock ride height camaros? Do you accept paypal? If so I'll take em.
Stainless Power Longtube headers, off road mids, stock H pipe, flowmaster mufflers, Vararam tune model intake, NightFury cam, and 91 octane email tune from Dynosteve @ rdpmotorsport.com. 473 rwhp and 430 ft. Lbs. @3,235 ft elevation.
01-19-2016, 04:56 PM | #4 |
Obsessive camaro disorder
What's the advantage over stock?
**2010 2ss/rs**
01-19-2016, 05:40 PM | #5 |
Sold !!!!1
01-19-2016, 07:17 PM | #6 |
From BMRs site.
Launching harder, reducing wheel hop, and adding cornering consistency to your 2010-2014 Chevrolet Camaro or Pontiac GM is easy with lower control arms from BMR Suspension. Stock stamped steel control arms with soft rubber bushings deflect under load and absorb power instead of transferring it to the tires. BMR’s polyurethane, non-adjustable trailing arms for Camaros and G8s (TCA026) are manufactured from heavy-duty 1x2-inch boxed steel tubing. The open end is formed from CNC laser cut, CNC formed 3/16-inch steel plate. This design gives you a strong control arm that greatly improves performance. Greasable, 95-durometer bushings add a solid, more responsive feel over the stock rubber bushings. BMR’s bushings are internally fluted, which allows grease to evenly coat the inner sleeve. These flutes also direct grease to the outer edge of the bushing, keeping the thrust surface lubricated. This efficient lubrication ensures quiet, reliable operation over the life of the bushings. BMR Suspension designed the TCA026 to work well in street performance, drag race, and road race applications. The stock trailing arms flex under cornering loads giving you inconsistent handling characteristics. Combine this with soft bushings that have massive amounts of deflection and you’re left with poor performance. The TCA026’s heavy-duty construction eliminates trailing arm flex, giving you much improved repeatability on the street, starting line, or in the corners. BMR’s polyurethane bushings are designed to be compliant enough to give you a comfortable ride and absorb NVH, while remaining firm enough to stand up to high loads of any performance environment. The bushings easily handle the high compression loads of hard launches and hard acceleration, yet offer plenty of articulation for great handling. These are the perfect upgrade for the enthusiast looking to improve performance at an affordable price, while maintaining acceptable NVH levels and ride quality. When performance is a must, rely on BMR Suspension! BMR Suspension’s TCA026 non-adjustable polyurethane lower control arms are available in red and black hammertone powdercoat for long-lasting good looks. Installation time is about 1 hour. Proudly made in the U.S.A.
